Basically, I want it to check if its a randomized MAC first and if it isn’t THEN do a lookup
rule "LookupMACVendor"
has_field("source_mac")
let macvendor = lookup_value("mac-lookup", $message.source_mac);
let source_mac_vendor = macvendor;
set_field("source_mac_vendor", macvendor);
rule "ParseMACForRandomization"
has_field("source_mac") AND (contains("2", substring(to_string($message.source_mac),1,2),true) OR contains("6", substring(to_string($message.source_mac),1,2),true) OR contains("a", substring(to_string($message.source_mac),1,2), true) OR contains("e", substring(to_string($message.source_mac),1,2), true))
set_field("source_mac_randomized", "True");
So I set ParseMACForRandomization in the one stage and below it in the other stage below I changed the rule to say
has_field("source_mac") AND !has_field("source_mac_randomized")
Sequentially, you have "ParseMACForRandomization" in a lower number stage from "LookupMACVendor" so that "ParseMACForRandomization" will run first, then when it gets to the next stage it will run "LookupMACVendor" - correct? Then make sure your stage rules are set up to pass properly to the next stage with something like "At least one of the rules on this stage matches the message…
Side note - I love that an option is “None or more rules on this stage match”… “always go to next stage” may have been better…
has_field("source_mac") AND NOT
set_field("source_mac_randomized", "FALSE");
You may be able to shorten processing with (Untested ):
regex("^[^26ae]{2}",to_string($message.source_mac)) == ""
EDIT: … or even:
