Index error after one ES node crashed
When clicking on the Search link in graylog, it is now giving the following error:
While retrieving data for this widget, the following error(s) occurred:
  • Elasticsearch exception [type=index_not_found_exception, reason=no such index ].
This occurred after one of the ES nodes crashed. It was restarted and Graylog now reports:
Elasticsearch cluster is green. Shards: 136 active, 0 initializing, 0 relocating, 0 unassigned,
There is a backlog of messages currently that its working through, however the process buffer and the output buffer are both at 100%. There are 3 x Graylog nodes and 3 X ES nodes.
Any ideas on what could be the issue?
many thanks
Darrin
When the ES nodes crash I’m sure that your journal was filling up quick.
If the process buffer and the output buffer are both at 100% give Elasticsearch a few minutes to ingest logs from your journal. The amount of time depends on how many messages are left in the journal.
EDIT @darrinh
What do you see when executing this command?
curl -XGET http://localhost:9200/_cat/indices
What do you see in graylog, Elasticsearch Logs?
Hi there,
that query returns the following:
green open graylog_47 YfHKg0B7QdmybDhtbH4-Bw 4 0 20009885 0 15.7gb 15.7gb
green open graylog_46 JlOPoAt5RIWubu-cgUqvQg 4 0 20034290 0 15.3gb 15.3gb
green open graylog_49 NsswIRCrRJOH3B6w6-H2dQ 4 0 20010584 0 14.4gb 14.4gb
green open graylog_48 9hjMD3vFSgewL-_PSdzpFA 4 0 20000459 0 15.1gb 15.1gb
green open gl-system-events_2 BlVfXN_RTNGcU2DK-bQG5g 4 0 0 0 832b 832b
green open graylog_50 FVVo22JRQXCBHbfxvsNDiA 4 0 20019164 0 15.3gb 15.3gb
green open gl-system-events_3 TKR0Iw7aR06I21xYv9Sx6Q 4 0 0 0 832b 832b
green open gl-system-events_0 0DUHH3kASTKABL7l8szC9w 4 0 0 0 832b 832b
green open graylog_52 OouRanfrR5-dSRqT5BSszg 4 0 20003684 0 15.5gb 15.5gb
green open graylog_51 lpSFTKmDQxuIxVmV9zqLjw 4 0 20010395 0 15.2gb 15.2gb
green open gl-system-events_1 GgiD8fXgRfqR39nnzsQW3A 4 0 0 0 832b 832b
green open gl-system-events_6 ezkgzHQQSkOX_mTno1UJug 4 0 0 0 832b 832b
green open graylog_54 mr_qLlIERXW905wqNruvAw 4 0 20016804 0 14.5gb 14.5gb
green open graylog_53 gy3wn5pMReugjjYCw0fFqQ 4 0 20002959 0 14.8gb 14.8gb
green open gl-system-events_4 Wy4hPLUoQWGORUR20VO6pA 4 0 0 0 832b 832b
green open graylog_56 5HUYnTqBSFGxjR-YI1AxWg 4 0 20012099 0 15.7gb 15.7gb
green open gl-system-events_5 tez_k_QvTcymoemi3Z5wog 4 0 0 0 832b 832b
green open graylog_55 MXHD0iM5QAWRFcsGzldYyA 4 0 20015437 0 15.4gb 15.4gb
green open graylog_58 ov1BRy6-S4Kcs93zYZAN_g 4 0 20001513 0 14.9gb 14.9gb
green open graylog_57 _OUGQ2LTQ2Ckn4tIx3neZg 4 0 20004554 0 15.7gb 15.7gb
green open graylog_59 Jh057X9KRKerY0tAL27Raw 4 0 20022569 0 14.3gb 14.3gb
green open gl-events_6 xGu9O0EVQbm_ZX_08ebdDg 4 0 0 0 832b 832b
green open gl-events_1 GMuZeMPGRZqMPxpq-2H2iw 4 0 242 0 131.9kb 131.9kb
green open gl-events_0 CieUCs6fS_SoXcGadNUTrg 4 0 24 0 55.9kb 55.9kb
green open gl-events_5 SLG4ONFmQCKERuOLPE7Bow 4 0 959 0 297.6kb 297.6kb
green open gl-events_4 ef3nW638Q8yC9hhyeJbQ8w 4 0 8209 0 1.7mb 1.7mb
green open gl-events_3 X3HsZY81TbOWG0LYMf7oHQ 4 0 10660 0 2.3mb 2.3mb
green open gl-events_2 OT6SPV9fRcqkUO1sYWdCOQ 4 0 10657 0 2.3mb 2.3mb
green open graylog_61 mGeWUTlUSaGC8oz4RhriaA 4 0 20010363 0 15.7gb 15.7gb
green open graylog_60 TP0KzwLrRqaCZXEsldtFeQ 4 0 20015648 0 15.5gb 15.5gb
green open graylog_63 AR7Hq7nJRsu0CPVxTrfaEQ 4 0 62955669 135 64.4gb 64.4gb
green open graylog_62 qyZSteyHRaGPkStMokoY_g 4 0 135143037 64 104.8gb 104.8gb
green open graylog_45 rjqnwl3STkyXbTw_3k2Z2g 4 0 20009220 2469 15.5gb 15.5gb
green open graylog_44 c45ShOTYTAG2FctN2DlUNg 4 0 20012229 0 13.7gb 13.7gb
The process and output buffers have gotten back to 0% utilisation now, still getting that same error from the search.
many thanks
darrin
Do you see anything in ES logs they may point to what index that Graylog cant find. See if there is anything they may pertain to this issue.
I can’t see anything obvious, graylog shows this in the logs:
2021-10-05T15:49:19.588+11:00 ERROR [PivotAggregationSearch] Aggregation search query returned an error: Elasticsearch exception [type=index_not_found_exception, reason=no such index ].
If i set the search time to 5 days ago, I can see data, but any time after that gives the no index error.
ok, I did System > indices > [index name] > maintenance > on all of the indices and the search function has been restored.
thanks for your assistance.
cheers
darrin
:laughing: you beat me by seconds, I was going to ask you about that Glad it was resolved.
