Continuing the discussion from How to build directly from IntelliJ IDEA without command line "mvn compile" first?:
Indeed i eventually found related thing for this issue on github:
The statements:
There is a known issue with Maven and annotation processors.
Repleatedly invoking mvn compile after small code changes is not always calling annotation processors correctly. Instead you are forced to do a mvn clean compile in order to make sure that the sources will be generated completely.
one of the proposaled solution:
EDIT: According to this post from elucash there is another option, which enables incremental compilation directly on the maven-compiler-plugin.
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.3</version>
<configuration>
<compilerVersion>1.8</compilerVersion>
<source>1.8</source>
<target>1.8</target>
<useIncrementalCompilation>true</useIncrementalCompilation>
</configuration>
</plugin>
so, if we should change the following property from false to true ?
<maven.compiler.useIncrementalCompilation>false</maven.compiler.useIncrementalCompilation>
