Hi everyone, please how can I solve this error , graylog 2.5 on Centos7
error failure of the opening collector-sidecar on centos 7
what is your error message say? I do not speak french. As you just post this image I’m even not able to use online translator…
But most important, why you open another topic the same question is in Graylog on centos7
I guess that you had not downloaded the rpm.
Sorry jan , the error is : impossible to open: collector-sidecar
did you download the RPM before with wget for example to the location where you tried the command to install?
Or did you tried?
rpm -Uvh https://github.com/Graylog2/collector-sidecar/releases/download/0.1.8/collector-sidecar-0.1.8-1.x86_64.rpm
you do not understand what you are doing and just type commands a stranger is telling you into your console right?
no please it is works, Graylog Collector Sidecar is installed but i dont have logs yet
Thanks for your help Jan
now I can collect firewall logs through Graylog 2.5 , it is my first time with graylog
