I&R with Python
Create a script to disable an IP address in the API manager and after x amount of minutes re-enable it. I don’t understand how I can keep the client_ip field to be able to execute the methods.
#!/usr/bin/env python3
import time
import json
import requests
import sys
# URL de API KONG Manager
url = 'http://api.local:8001/services/MyAPI/plugins'
# Contador
def countdown(t):
    while t:
        mins, secs = divmod(t, 60)
        timer = '{:02d}:{:02d}'.format(mins, secs)
        print(timer, end="\r")
        time.sleep(1)
        t -= 1
# Bloqueo de Direccion TCP IP
def bloqueo(ip):
    data = {'name':'ip-restriction',
            'config.deny':ip}
    r = requests.post(url, data)
    data = r.json()
    print ('Bloqueado: %s' % data['config']['deny'])
    return data
# Eliminamos la regla, con ID de Plugin.
def eliminar(data):
    print('El ID del Plugin es: %s' % data['id'])
    print ('Desbloqueo: %s' % data['config']['deny'])
    r = requests.delete(url + '/' + data['id'])
    return r.status_code
# Function that prints text to standard error
def print_stderr(*args, **kwargs):
    print(*args, file=sys.stderr, **kwargs)
# Principal
if __name__ == "__main__":
    # Print out all input arguments.
    sys.stdout.write("All Arguments Passed In: " + ' '.join(sys.argv[1:]) + "\n")
    # Turn stdin.readlines() array into a string
    std_in_string = ''.join(sys.stdin.readlines())
    # Load JSON
    event_data = json.loads(std_in_string)
    # Extract some values from the JSON.
    sys.stdout.write("Values from JSON: \n")
    sys.stdout.write("Event Definition ID: " + event_data["event_definition_id"] + "\n")
    sys.stdout.write("Event Definition Title: " + event_data["event_definition_title"] + "\n")
    sys.stdout.write("Event Timestamp: " + event_data["event"]["timestamp"] + "\n")
    # Extract Message Backlog field from JSON.
    sys.stdout.write("\nBacklog:\n")
    for message in event_data["backlog"]:
        for field in message.keys():
            if (field == "client_ip"):
                sys.stdout.write("Field: " + field + "\t")
                sys.stdout.write("Value: " + str(message[field]) + "\n")
                ip = str(message[field])
    # Bloqueo de Direccion IP
    id = bloqueo(ip)
    # Espero 10 Minutos
    countdown(10)
    # Elimino Regla de Bloqueo
    if (eliminar(id) == 204):
        print ('Procedimiento de Bloqueo Exitoso')
    else:
        print ('Problemas en el Procedimiento de Bloqueo')
    # Return an exit value. Zero is success, non-zero indicates failure.
    exit(0)
The problem its here
Here its de error…
Any idea?
Here the notification:
I need the client_ip :smiley:
Thanks! Guys
Maybe simplier way would be to create field in alert definition, and then get it using:
event_data["event"]["fields"]["field_name"]
Replace field_name with your created field in alert definition.
I resolved in this way! Creating a file, log.txt with the message, and take the IP Address. Take a look.
import json
import sys
import time
import requests
url = ‘http://kong:8001/services/MyAPI/plugins
Funcion Extract IP
def extract_ip():
with open(‘log.txt’, ‘r’) as file:
data = file.read().replace(’\n’, ‘’)
string = “client_ip”
ip = (data[data.index(string)+11:data.index(string)+26])
ip = ip[1:-1]
return ip
Count Time
def countdown(t):
while t:
timer = ‘{:02d}:{:02d}’.format(mins, secs)
time.sleep(1)
t -= 1
Block IP
def bloqueo(client_ip):
data = {‘name’:‘ip-restriction’,
‘config.deny’:client_ip}
data = r.json()
return data
Delete API Manager Rule
def eliminar(data):
r = requests.delete(url + ‘/’ + data[‘id’])
Main Program
if name == “main”:
temp = sys.stdout #store original stdout object for later
sys.stdout = open(‘log.txt’,‘w’) #redirect all prints to this log file
sys.stdout.write("All Arguments Passed In: " + ’ '.join(sys.argv[1:]) + “\n”)
std_in_string = ‘’.join(sys.stdin.readlines())
Load JSON
sys.stdout.write(“Values from JSON: \n”)
sys.stdout.write("Event Definition ID: " + event_data[“event_definition_id”] + “\n”)
sys.stdout.write("Event Definition Title: " + event_data[“event_definition_title”] + “\n”)
sys.stdout.write("Event Timestamp: " + event_data[“event”][“timestamp”] + “\n”)
for message in event_data[“backlog”]:
sys.stdout.write("Field: " + field + “\t”)
sys.stdout.write("Value: " + str(message[field]) + “\n”)
sys.stdout.close()
sys.stdout = temp
sys.stdout = open(‘ip_block.txt’,‘w’) #redirect all prints to this log file
IP a Bloquear
ip = extract_ip()
sys.stdout.write("Direccion IP: " + ip + “\n”)
Block IP
id_block = bloqueo(ip)
sys.stdout.write("ID del Bloqueo: " + str(id_block[‘id’]) + “/n”)
sys.stdout.close()
sys.stdout = temp
Time Rule Life 1 Minute
countdown(60)
Delete the Rule
eliminar(id_block)
exit(0)
Please post your source code in ` code ` or ``` code ```, because it’s not correctly formated in this forum.
Sorry!
import json
import sys
import time
import requests
url = 'http://kong:8001/services/MyAPI/plugins'
# Funcion Extract IP
def extract_ip():
    with open('log.txt', 'r') as file:
        data = file.read().replace('\n', '')
    string = "client_ip"
    ip = ip[1:-1]
    return ip
# Count Time
def countdown(t):
    while t:
        time.sleep(1)
        t -= 1
# Block IP
            'config.deny':client_ip}
    data = r.json()
    return data
# Delete API Manager Rule
def eliminar(data):
# Main Program
    sys.stdout = open('log.txt','w') #redirect all prints to this log file
    # Load JSON
    sys.stdout.close()
    sys.stdout = temp
    sys.stdout = open('ip_block.txt','w') #redirect all prints to this log file
    # IP a Bloquear
    ip = extract_ip()
    sys.stdout.write("Direccion IP: " + ip + "\n")
     # Block IP
    sys.stdout.write("ID del Bloqueo: " + str(id_block['id']) + "/n")
    sys.stdout.close()
    sys.stdout = temp
    # Time Rule Life 1 Minute
    countdown(60)
    # Delete the Rule
    eliminar(id_block)
    exit(0)
