Issue with AzureAD Pipeline Rule - Client IP for Map
I am trying to create a map of IP’s addresses of failed logins.
I followed the guide here to setup GeoIP but the pipeline rule isnt finding the IP Address (ClientIP)
The “Input” Extractor correctly formats the message, per this guide
  • OS Information: Ubuntu 20.04
  • Package Version: GrayLog 4.3.9
I have tried following steps at 15048
Source Message: (some details changed for privacy)
{"CreationTime": "2022-11-29T19:33:16", "Id": "a8136cf2-ca32-4602-b990-e9b2155a2301", "Operation": "UserLoginFailed", "OrganizationId": "000000-b665-0000-8346-000016c7c39e", "RecordType": 15, "ResultStatus": "Failed", "UserKey": "9496049e-fbc6-494b-8fc7-26b89486412c", "UserType": 0, "Version": 1, "Workload": "AzureActiveDirectory", "ClientIP": "161.97.159.169", "ObjectId": "00000002-0000-0ff1-ce00-000000000000", "UserId": "user@domain.com", "AzureActiveDirectoryEventType": 1, "ExtendedProperties": [{"Name": "ResultStatusDetail", "Value": "UserError"}, {"Name": "UserAgent", "Value": "BAV2ROPC"}, {"Name": "UserAuthenticationMethod", "Value": "16"}, {"Name": "RequestType", "Value": "OAuth2:Token"}], "ModifiedProperties": [], "Actor": [{"ID": "9496049e-fbc6-494b-8fc7-26b89486412c", "Type": 0}, {"ID": "user@domain.com", "Type": 5}], "ActorContextId": "2d04b444-b665-4d7d-8346-728b16c7c39e", "ActorIpAddress": "161.97.159.169", "InterSystemsId": "e34c081c-a363-4a9f-bbcd-2c1391ecbaba", "IntraSystemId": "a8136cf2-ca32-4602-b990-e9b2155a2301", "SupportTicketId": "", "Target": [{"ID": "00000002-0000-0ff1-ce00-000000000000", "Type": 0}], "TargetContextId": "2d04b444-b665-4d7d-8346-728b16c7c39e", "ApplicationId": "00000002-0000-0ff1-ce00-000000000000", "DeviceProperties": [{"Name": "BrowserType", "Value": "Other"}, {"Name": "IsCompliantAndManaged", "Value": "False"}], "ErrorNumber": "50126", "LogonError": "InvalidUserNameOrPassword", "timestamp": "2022-11-29 19:33:16.000"}
Simulation of above message:
Example Message:
Pipeline Rule:
there was mention to add debug to the rule, but not sure what to actually add…
Heoo @DrunkMunki
Bug rule , Here is mine
rule "GeoIP lookup: srcip"
  has_field("srcip")
let geo = lookup("geoip", to_string($message.srcip));
 set_field("src_ip_geo_location", geo["coordinates"]);
 set_field("src_ip_geo_country", geo["country"].iso_code);
 set_field("src_ip_geo_city", geo["city"].names.en);
 debug(geo);
Have you tried testing those IP Address under ClientIP?
I used you ClientIP data in my setup seams to work.
On the left pane on the global search do you see any fields pertaining to GeoIP? I know this was a issue back a couple months ago the naming convention change but they changed it back.
Noticed for some reason its not like my Pipe Rule from above.
thanks for the super quick reply @gsmith
I have added the debug code but nothing shows in the server.log file when i try and ‘simulate’ the process
updated_rule
from my understanding the below varies on the field data,
has_field("ClientIP")
i did a ‘src’ lookup and got no results
src_lookup
I also looked up ClientIP and got results
ClientIP_lookup
I did notice when i tried to click on
lookuptable
I get the errors in the log:
WARN [LookupTableService] Lookup table <watchlist> does not exist
Ok
that was mine above using src but for you try something like "city_name" , “geo” , “geolocation” or “clientip” see is anything come up. This is just checking for fields incase it was rename or bug issue. Also click on this part, I marked it in red
Oh gotcha, let me check
EDIT; @DrunkMunki I post wrong screen shot , I corrected it just now
Yeah, clicked on both links for the fields, same result.
the Bold text indicates which one was selected.
Not sure if this was answer , but does this test section in GEO lookup-table work?
I used your ip address from above under ClientIP
EDIT : @DrunkMunki If that doesn’t work then you may have a configuration issue, not sure yet
No when i click on the Lookup for GeoIP i get the error, which goes into a loop refreshing the page
unavailable
and error at the bottom
and the log floods with
2022-11-30T15:26:41.619+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:42.621+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:43.619+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:44.620+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:45.621+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:46.617+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:47.615+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:48.610+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:49.613+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:50.624+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
2022-11-30T15:26:51.625+11:00 WARN  [LookupTableService] Lookup table <watchlist> does not exist
Yeppers,
I was afraid of that,
Check LIst:
Need to make sure 100% you have everything installed,
sudo apt-get update && sudo apt-get install graylog-server graylog-enterprise-plugins graylog-integrations-plugins graylog-enterprise-integrations-plugins
The status of MongoDb, Graylog & Elasticsearch is Good.
systemctl status graylog-server
systemctl status elasticsearch
systemctl status mongo
Under System/Configuration make sure Pipeline is after message chain
Same section , bottom of that page ensure it looks something like this
EDIT: if all that is correct, try restart Graylog service and tail -f graylog log file look for any errors and warnings
thanks @gsmith
ok ran the update and was missing: graylog-enterprise-plugins graylog-integrations-plugins graylog-enterprise-integrations-plugins
was missing the MaxMind ASN database, downloaded and put in same location as City one.
restarted graylog service and is showing good logs
2022-11-30T15:42:01.131+11:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/6372e6e5e2c93641eec8752e [@2959cd47] STARTING
2022-11-30T15:42:01.134+11:00 INFO  [LookupTableService] Data Adapter geoip/63868ff2f66a3f67c30b8064 [@2cb3c7ed] STARTING
2022-11-30T15:42:01.137+11:00 INFO  [LookupTableService] Data Adapter watchlist-mongo/6372e6e5e2c93641eec8752e [@2959cd47] RUNNING
2022-11-30T15:42:01.143+11:00 INFO  [LookupTableService] Data Adapter geoip/63868ff2f66a3f67c30b8064 [@2cb3c7ed] RUNNING
2022-11-30T15:42:01.143+11:00 INFO  [LookupDataAdapterRefreshService] Adding job for <geoip/63868ff2f66a3f67c30b8064/@2cb3c7ed> [interval=3600000ms]
2022-11-30T15:42:01.207+11:00 INFO  [LookupTableService] Cache watchlist-cache/6372e6e5e2c93641eec8752c [@1d40a5b2] STARTING
2022-11-30T15:42:01.209+11:00 INFO  [LookupTableService] Cache watchlist-cache/6372e6e5e2c93641eec8752c [@1d40a5b2] RUNNING
2022-11-30T15:42:01.209+11:00 INFO  [LookupTableService] Cache geoip/6386902ef66a3f67c30b80e3 [@bfeb005] STARTING
2022-11-30T15:42:01.209+11:00 INFO  [LookupTableService] Cache geoip/6386902ef66a3f67c30b80e3 [@bfeb005] RUNNING
2022-11-30T15:42:01.221+11:00 INFO  [LookupTableService] Starting lookup table watchlist/6372e6e5e2c93641eec87530 [@53fa8941] using cache watchlist-cache/6372e6e5e2c93641eec8752c [@1d40a5b2], data adapter watchlist-mongo/6372e6e5e2c93641eec8752e [@2959cd47]
2022-11-30T15:42:01.221+11:00 INFO  [LookupTableService] Starting lookup table geoip/6386dd49f66a3f67c30c2258 [@ec1d9e6] using cache geoip/6386902ef66a3f67c30b80e3 [@bfeb005], data adapter geoip/63868ff2f66a3f67c30b8064 [@2cb3c7ed]
and confirmed the country is now being added
location
Also didnt have the “Geo-Location” Processor enabled…
Also Chrome Cache was affecting the lookup able page, using Firefox i was able to access it, so not sure where in the process this was fixed… but everything 100% now.
thanks again gsmith!
@DrunkMunki
awesome-yes-will-ferrell (1)
Happy Logging my friend :+1: you got luck, Im heading home from work in a few AHAHA
