zhou-mfk
(Zhou Mfk)
April 20, 2017, 7:13am
1
I understand the field source is the IP address of the sending message to graylog.
My graylog arch is as follows:
3 nodes graylog as a cluster
3 nodes elasticsearch as a cluster
inputs graylog cluster use tcp . I use rsyslog sent message to graylog.
I question about field source When I use HAProxy proxy inputs port. The field source value is HAProxy‘s IP .
zls-183 is a hostname use rsyslog sent message to graylog.
10.201.240.3 is haproxy ip.
I think the field source value is hostname/ip(zls-183) don’t HAProxy’s IP. Is there any way to solve it?
jochen
(Jochen)
April 20, 2017, 7:23am
2
What type of input are you using in Graylog?
How exactly did you configure your rsyslog daemons?
zhou-mfk
(Zhou Mfk)
April 24, 2017, 2:25am
3
input is tcp
rsyslog configure is:
a) /etc/rsyslog.conf
# cat ../rsyslog.conf | grep -Ev "^$|^#"
$WorkDirectory /var/lib/rsyslog
module(load="imuxsock") # provides support for local system logging (e.g. via logger command)
module(load="imklog") # provides kernel logging support (previously done by rklogd)
module(load="imfile")
$template IpTemplate,"%HOSTNAME% %fromhost-ip%%syslogtag%%msg:::sp-if-no-1st-sp%%msg:::drop-last-lf%\n"
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
$IncludeConfig /etc/rsyslog.d/*.conf
*.info;mail.none;authpriv.none;cron.none;local2.none /var/log/messages
authpriv.* /var/log/secure
mail.* /var/log/maillog
cron.* /var/log/cron
*.emerg :omusrmsg:*
uucp,news.crit /var/log/spooler
local7.* /var/log/boot.log
b) # cat /etc/rsyslog.d/graylog.conf
ruleset(name="graylog") {
action(type="omfwd"
Protocol="tcp"
Target="10.201.240.4"
Template="IpTemplate"
Port="1111" # This is a proxy prot for haproxy
queue.type="linkedlist"
queue.filename="q_fwd"
queue.timeoutenqueue="0"
queue.size="8000000"
queue.highwatermark="5000000"
queue.lowwatermark="4000000"
queue.discardmark="7200000"
queue.maxdiskspace="10g"
queue.saveonshutdown="on"
queue.dequeuebatchsize="10240"
queue.workerThreads="4"
queue.workerThreadMinimumMessages="800000"
stop
input(type="imfile"
File="/root/nginx_test.log" # This is a test log file
Tag="ngx_test"
PersistStateInterval="1000"
reopenOnTruncate="on"
addMetadata="on"
Ruleset="graylog"
zhou-mfk
(Zhou Mfk)
April 24, 2017, 2:32am
4
In this picture the source: 10.201.240.3 is a node for graylog cluster. The other two nodes are:10.201.240.1 and 10.201.240.2
haproxy virtual IP address is :10.201.240.4 .use keepalived
zhou-mfk
(Zhou Mfk)
April 24, 2017, 2:36am
5
The current virtual IP 10.201.240.4 and 10.201.240.3 are on the same server。
jochen
(Jochen)
April 24, 2017, 6:22am
6
See https://github.com/Graylog2/graylog-guide-syslog-linux/blob/master/README.md for information about how to configure rsyslog (especially the required template) to work with Graylog.
If you’re not using a RFC 5424-compatible template, you’ll have to use extractors or processing pipeline rules to extract the information from the syslog messages in a structured manner.
