Mr_Reyes
(John Reyes)
October 3, 2017, 1:58pm
1
Hey there
is there a way to set the source in the syslog message to be the ip form which it arrived, and not the one the device enters as source?
i have a lot of devices, that sets their username as source, instead of their ip or hostname, which makes it very difficult to extrapolate the logs…
b4 i used netxms as syslog parser, and i could change it so…
jochen
(Jochen)
October 3, 2017, 4:36pm
2
Yes, you could copy the content of the “gl2_remote_ip” field (which contains the IP address of the client which sent the message to Graylog) into the “source” field using a Copy Input extractor or a pipeline rule (set_field() ).
Mr_Reyes
(John Reyes)
October 3, 2017, 4:38pm
3
than!
im new to graylog, but i will give it a go
Mr_Reyes
(John Reyes)
October 3, 2017, 4:56pm
4
hmmm any pointers, or ref to the documentation?
cant seem to figure out how to build the extractor (which field, and what type?)
jochen
(Jochen)
October 3, 2017, 4:58pm
5
I mentioned the field names and the Extractor type in my first post…
Mr_Reyes
(John Reyes)
October 4, 2017, 1:32pm
6
hmmm here is an example of the messages that does the problems:
i dont see the gl2_remote_ip field? or any other field i can extract the source ip from.
sorry for sounding n00b, but im all new to graylog
jochen
(Jochen)
October 4, 2017, 3:12pm
7
Fields prefixed with “gl2_” are hidden by default.
I’d recommend using a pipeline rule to to overwrite the “source” field.
