I can’t connect to the token I created for my user in Graylog. I did not encounter this problem in different graylog versions. I’m using Opensearch on the Graylog backend. Do I need to add a parameter to the graylog conf file for the token? I am requesting your support.
Opensearch version : 2.5.0
Graylog version: 5.0.2
Error received: Error: Failure when receiving data from the peer
