Hi, i have a proxy with https that should strip the ssl and redirect http->https and than go to http to the graylog inside LAN, i’ve tryed a lot of different configurations, none of them worked so far, the web interface and api used in different ports, i can access the web interface but it has issues with using the api
Error message
Bad request
Original Request
GET http://graylog.example.com:12900/system/cluster/node
Status code
undefined
Full error message
Error: Request has been terminated
Possible causes: the network is offline, Origin is not allowed by Access-Control-Allow-Origin, the page is being unloaded, etc.
this is the error i’m getting. and if i go for the link it works fine from any point (internal and external)
did anyone tryed something like this before?
