HTTPS implementation, blank page
Upon starting my Graylog server the port (9000) opens and the server logs show it is running however when entering ‘https://hostname:9000’, as well as https://IP:9000’ it returns a blank page only showing scripts in the body when viewed through inspector.
  • OS Information: Ubuntu 22.04
  • Package Version: Graylog 5.0
journalctl logs show nothing but the server starting and stopping when I start and stop it for debugging.
Server logs:
– Begin Server.log –
2023-07-13T15:52:37.525-05:00 INFO [ImmutableFeatureFlagsCollector] Following feature flags are used: {default properties file=[scripting_api_preview=off, search_filter=on]}
2023-07-13T15:52:37.858-05:00 INFO [CmdLineTool] Loaded plugin: Integrations 5.0.8 [org.graylog.integrations.IntegrationsPlugin]
2023-07-13T15:52:37.858-05:00 INFO [CmdLineTool] Loaded plugin: Collector 5.0.8 [org.graylog.plugins.collector.CollectorPlugin]
2023-07-13T15:52:37.859-05:00 INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 5.0.8 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2023-07-13T15:52:37.859-05:00 INFO [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 5.0.8+4c22532 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2023-07-13T15:52:37.859-05:00 INFO [CmdLineTool] Loaded plugin: OpenSearch 2 Support 5.0.8+4c22532 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
2023-07-13T15:52:37.877-05:00 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/etc/graylog/graylog.jks -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2023-07-13T15:52:38.005-05:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “4.7.1”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “5.19.0-46-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.6+10”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@8a2a6a]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName=‘null’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘30000 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2023-07-13T15:52:38.009-05:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “4.7.1”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “5.19.0-46-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.6+10”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@8a2a6a]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName=‘null’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘30000 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2023-07-13T15:52:38.016-05:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:30}] to localhost:27017
2023-07-13T15:52:38.016-05:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:29}] to localhost:27017
2023-07-13T15:52:38.016-05:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=15312666}
2023-07-13T15:52:38.041-05:00 INFO [connection] Opened connection [connectionId{localValue:3, serverValue:31}] to localhost:27017
2023-07-13T15:52:38.065-05:00 INFO [MongoDBPreflightCheck] Connected to MongoDB version 6.0.7
2023-07-13T15:52:38.416-05:00 INFO [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version Elasticsearch:7.10.2
2023-07-13T15:52:38.483-05:00 INFO [Version] HV000001: Hibernate Validator null
2023-07-13T15:52:39.960-05:00 INFO [InputBufferImpl] Message journal is enabled.
2023-07-13T15:52:39.971-05:00 INFO [NodeId] Node ID: c578242e-6698-4195-83a9-6a92e818e0bf
2023-07-13T15:52:40.073-05:00 INFO [LogManager] Loading logs.
2023-07-13T15:52:40.100-05:00 INFO [LogManager] Logs loading complete.
2023-07-13T15:52:40.103-05:00 INFO [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2023-07-13T15:52:40.113-05:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “4.7.1”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “5.19.0-46-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.6+10”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@8a2a6a]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName=‘null’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘30000 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2023-07-13T15:52:40.114-05:00 INFO [connection] Opened connection [connectionId{localValue:5, serverValue:33}] to localhost:27017
2023-07-13T15:52:40.115-05:00 INFO [connection] Opened connection [connectionId{localValue:4, serverValue:32}] to localhost:27017
2023-07-13T15:52:40.115-05:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=17, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=4300152}
2023-07-13T15:52:40.116-05:00 INFO [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, “version”: “4.7.1”}, “os”: {“type”: “Linux”, “name”: “Linux”, “architecture”: “amd64”, “version”: “5.19.0-46-generic”}, “platform”: “Java/Eclipse Adoptium/17.0.6+10”} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=, codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@8a2a6a]}, clusterSettings={hosts=[localhost:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName=‘null’, serverSelector=‘null’, clusterListeners=‘’, serverSelectionTimeout=‘30000 ms’, localThreshold=‘30000 ms’}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=, maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners=‘’, serverMonitorListeners=‘’}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName=‘null’, compressorList=, uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2023-07-13T15:52:40.116-05:00 INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2023-07-13T15:52:40.118-05:00 INFO [connection] Opened connection [connectionId{localValue:6, serverValue:34}] to localhost:27017
2023-07-13T15:52:40.229-05:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2023-07-13T15:52:40.452-05:00 INFO [ElasticsearchVersionProvider] Elasticsearch cluster is running Elasticsearch:7.10.2
2023-07-13T15:52:40.848-05:00 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2023-07-13T15:52:40.917-05:00 INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy .
2023-07-13T15:52:41.277-05:00 INFO [ServerBootstrap] Graylog server 5.0.8+4c22532 starting up
2023-07-13T15:52:41.277-05:00 INFO [ServerBootstrap] JRE: Eclipse Adoptium 17.0.6 on Linux 5.19.0-46-generic
2023-07-13T15:52:41.277-05:00 INFO [ServerBootstrap] Deployment: deb
2023-07-13T15:52:41.277-05:00 INFO [ServerBootstrap] OS: Ubuntu 22.04.2 LTS (jammy)
2023-07-13T15:52:41.278-05:00 INFO [ServerBootstrap] Arch: amd64
2023-07-13T15:52:41.286-05:00 INFO [connection] Opened connection [connectionId{localValue:7, serverValue:35}] to localhost:27017
2023-07-13T15:52:41.345-05:00 INFO [ServerBootstrap] Running 48 migrations…
2023-07-13T15:52:41.643-05:00 INFO [PeriodicalsService] Starting 26 periodicals …
2023-07-13T15:52:41.643-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.653-05:00 INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2023-07-13T15:52:41.657-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.659-05:00 INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2023-07-13T15:52:41.659-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2023-07-13T15:52:41.665-05:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2023-07-13T15:52:41.665-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2023-07-13T15:52:41.669-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2023-07-13T15:52:41.670-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexBlockCheck] periodical in [0s], polling every [30s].
2023-07-13T15:52:41.671-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2023-07-13T15:52:41.705-05:00 WARN [LookupTableService] Unable to load data adapter watchlist-mongo of type mongodb, missing a factory. Is a required plugin missing?
2023-07-13T15:52:41.713-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2023-07-13T15:52:41.726-05:00 INFO [connection] Opened connection [connectionId{localValue:9, serverValue:37}] to localhost:27017
2023-07-13T15:52:41.726-05:00 INFO [connection] Opened connection [connectionId{localValue:8, serverValue:36}] to localhost:27017
2023-07-13T15:52:41.733-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.742-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2023-07-13T15:52:41.752-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2023-07-13T15:52:41.760-05:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.764-05:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2023-07-13T15:52:41.771-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2023-07-13T15:52:41.780-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.807-05:00 INFO [LookupTableService] Cache watchlist-cache/6485f06fe4bf2a70b59869dd [@f153ea9] STARTING
2023-07-13T15:52:41.808-05:00 INFO [LookupTableService] Cache watchlist-cache/6485f06fe4bf2a70b59869dd [@f153ea9] RUNNING
2023-07-13T15:52:41.827-05:00 WARN [LookupTableService] Lookup table watchlist is referencing a missing data adapter 6485f06fe4bf2a70b59869db, check if it started properly.
2023-07-13T15:52:41.829-05:00 INFO [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [1s].
2023-07-13T15:52:41.834-05:00 INFO [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2023-07-13T15:52:41.845-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2023-07-13T15:52:41.879-05:00 INFO [Periodicals] Starting [org.graylog2.periodical.UserSessionTerminationPeriodical] periodical, running forever.
2023-07-13T15:52:41.884-05:00 INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2023-07-13T15:52:41.884-05:00 INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2023-07-13T15:52:41.885-05:00 INFO [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2023-07-13T15:52:41.908-05:00 INFO [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2023-07-13T15:52:41.908-05:00 INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2023-07-13T15:52:41.958-05:00 INFO [JerseyService] Enabling CORS for HTTP endpoint
2023-07-13T15:52:42.782-05:00 INFO [NetworkListener] Started listener bound to [192.168.31.244:9000]
2023-07-13T15:52:42.784-05:00 INFO [HttpServer] [HttpServer] Started.
2023-07-13T15:52:42.784-05:00 INFO [JerseyService] Started REST API at <192.168.31.244:9000>
2023-07-13T15:52:42.785-05:00 INFO [ServiceManagerListener] Services are healthy
2023-07-13T15:52:42.785-05:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2023-07-13T15:52:42.786-05:00 INFO [ServerBootstrap] Services started, startup times in ms: {BufferSynchronizerService [RUNNING]=0, UrlWhitelistService [RUNNING]=0, FailureHandlingService [RUNNING]=0, UserSessionTerminationService [RUNNING]=0, InputSetupService [RUNNING]=0, GracefulShutdownService [RUNNING]=1, LocalKafkaMessageQueueWriter [RUNNING]=1, LocalKafkaMessageQueueReader [RUNNING]=1, OutputSetupService [RUNNING]=7, MongoDBProcessingStatusRecorderService [RUNNING]=11, LocalKafkaJournal [RUNNING]=11, EtagService [RUNNING]=13, JobSchedulerService [RUNNING]=23, StreamCacheService [RUNNING]=27, GeoIpDbFileChangeMonitorService [RUNNING]=27, ConfigurationEtagService [RUNNING]=28, PrometheusExporter [RUNNING]=48, LookupTableService [RUNNING]=176, PeriodicalsService [RUNNING]=266, JerseyService [RUNNING]=1142}
2023-07-13T15:52:42.789-05:00 INFO [ServerBootstrap] Graylog server up and running.
2023-07-13T15:52:42.807-05:00 INFO [InputLauncher] Not auto-starting input [GELF TCP/GreyLog Server /648720d7684e1b72a3ed1b61] - desired state is STOPPED
2023-07-13T15:52:42.808-05:00 INFO [InputLauncher] Launching input [GELF UDP/GELF_UDP/64872bfe52489963a11b2f59] - desired state is RUNNING
2023-07-13T15:52:42.813-05:00 INFO [InputStateListener] Input [GELF UDP/64872bfe52489963a11b2f59] is now STARTING
2023-07-13T15:52:42.861-05:00 INFO [InputStateListener] Input [GELF UDP/64872bfe52489963a11b2f59] is now RUNNING
– End Server.log –
  • Configuration
– Begin Server.conf –
is_leader = true
password_secret = *******
root_username = *******
root_password_sha2 = *******
http_bind_address = 192.168.31.244:9000
http_publish_uri = https://192.168.31.244:9000/
http_external_uri = https://192.168.31.244:9000/api/
http_enable_cors = true
http_enable_gzip = true
http_max_header_size = 8192
http_thread_pool_size = 64
http_enable_tls = true
http_tls_cert_file = /etc/graylog/server/cert/ *******
http_tls_key_file = /etc/graylog/server/cert/ *******
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
– End Server.conf –
I have seen similar problems solved by ensuring the http_enable_cors is enabled as well as ensuring that the http_publish_uri is declared, both instances are true in my case but the solutions have not solved my predicament.
I have also tried entering the following into the configuration with no success:
web_listen_uri = https://192.168.31.244:9000/
rest_transport_uri = https://192.168.31.244:9000/api
rest_tls_cert_file = /etc/graylog/server/cert/*******
rest_tls_key_file = /etc/graylog/server/cert/*******
rest_tls_key_password = *******
I attempted to throw the test message from blog 21828
and was met with ‘Connection refused’.
I am wanting to leverage the expertise of those who are more versed in this system than myself, thank you all in advance.
After reinstalling the missing plugin for the WARN code “Lookup table watchlist is referencing a missing data adapter 6485f06fe4bf2a70b59869db, check if it started properly.”
The webpage is still not loading and now there are no WARN or ERROR codes in my server.log
Any ideas?
This is unfortunately still a complex topic with a lot of pitfalls :frowning: .
I spent a bit of time earlier this year writing up all the places i got stuck, worth a read: How-To Guide: Securing Graylog with TLS
If you go through all of that and have issues let me know.
Thank you Drew, I have gone through your very detailed guide however I am still left with a blank webpage.
Can you confirm you are using a hostname for http_publish_uri? This must be a hostname and must be a value that is present in the cert’s common name and subject alternative name (SAN).
I have changed the http_publish_uri to the following:
http_publish_uri = https://graylog.spe, then tried http_publish_uri = http://graylog.spe.
The parameters set when creating the certs were for the CN = graylog.spe & SAN = dns:CN so they are both pointing to graylog.spe.
In the inspector tab screenshot, do you have any errors on the Console tab?
One other thing i noticed is you have http_external_uri declared, but it is a different path (its adding api/). Can you commend out that line (add a # a the beginning of the line) and see if that changes anything?
Thanks,
Drew
Disabling the http_external_uri did the trick.
Thank you very much for your expertise and willingness to help!
