Http line is too long
hi,
I have set http.max_initial_line length to 150kb in ES clusters elasticsearch.yml (GL 2.3.0, ES 5.5)
For some reason, I still get these errors. Any idea on where to look at, or is this a place to make a github bug report?
[2017-08-08 12:15:56,872][WARN ][http.netty               ] [es-graylog-es09v] Caught exception while handling client http traffic, closing connection [id: 0x27f10098, /IP_of_my_graylog_node:33028 => /IP_of_my_ES_node:9200]
org.jboss.netty.handler.codec.frame.TooLongFrameException: An HTTP line is larger than 4096 bytes.
        at org.jboss.netty.handler.codec.http.HttpMessageDecoder.readLine(HttpMessageDecoder.java:670)
        at org.jboss.netty.handler.codec.http.HttpMessageDecoder.decode(HttpMessageDecoder.java:184)
        at org.jboss.netty.handler.codec.http.HttpMessageDecoder.decode(HttpMessageDecoder.java:102)
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:500)
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
        at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:75)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
        at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
        at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
        at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
        at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
        at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
        at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
[2017-08-08 12:15:56,872][WARN ][http.netty               ] [es-graylog-es09v] Caught exception while handling client http traffic, closing connection [id: 0x27f10098, /IP_of_my_graylog_node:33028 :> /IP_of_my_ES_node:9200]
java.lang.IllegalArgumentException: empty text
        at org.jboss.netty.handler.codec.http.HttpVersion.<init>(HttpVersion.java:89)
        at org.jboss.netty.handler.codec.http.HttpVersion.valueOf(HttpVersion.java:62)
        at org.jboss.netty.handler.codec.http.HttpRequestDecoder.createMessage(HttpRequestDecoder.java:75)
        at org.jboss.netty.handler.codec.http.HttpMessageDecoder.decode(HttpMessageDecoder.java:191)
        at org.jboss.netty.handler.codec.replay.ReplayingDecoder.cleanup(ReplayingDecoder.java:554)
        at org.jboss.netty.handler.codec.frame.FrameDecoder.channelDisconnected(FrameDecoder.java:365)
        at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102)
        at org.jboss.netty.channel.Channels.fireChannelDisconnected(Channels.java:396)
        at org.jboss.netty.channel.socket.nio.AbstractNioWorker.close(AbstractNioWorker.java:360)
        at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.handleAcceptedSocket(NioServerSocketPipelineSink.java:81)
        at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:36)
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779)
        at org.jboss.netty.handler.codec.oneone.OneToOneEncoder.handleDownstream(OneToOneEncoder.java:54)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591)
        at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784)
        at org.jboss.netty.channel.SimpleChannelHandler.closeRequested(SimpleChannelHandler.java:334)
        at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:260)
        at org.elasticsearch.http.netty.pipelining.HttpPipeliningHandler.handleDownstream(HttpPipeliningHandler.java:105)
        at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582)at org.jboss.netty.channel.Channels.close(Channels.java:812)
    at org.jboss.netty.channel.AbstractChannel.close(AbstractChannel.java:205)
    at org.elasticsearch.http.netty.NettyHttpServerTransport.exceptionCaught(NettyHttpServerTransport.java:467)
    at org.elasticsearch.http.netty.HttpRequestHandler.exceptionCaught(HttpRequestHandler.java:67)
    at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:112)
    at org.jboss.netty.channel.SimpleChannelHandler.exceptionCaught(SimpleChannelHandler.java:156)
    at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:130)
    at org.jboss.netty.channel.SimpleChannelUpstreamHandler.exceptionCaught(SimpleChannelUpstreamHandler.java:153)
    at org.jboss.netty.handler.codec.frame.FrameDecoder.exceptionCaught(FrameDecoder.java:377)
    at org.jboss.netty.channel.Channels.fireExceptionCaught(Channels.java:525)
    at org.jboss.netty.channel.AbstractChannelSink.exceptionCaught(AbstractChannelSink.java:48)
    at org.jboss.netty.channel.DefaultChannelPipeline.notifyHandlerException(DefaultChannelPipeline.java:658)
    at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:566)
This is a bug in Graylog 2.3.0 which will be fixed in Graylog 2.3.1:
As a workaround, you can increase the http.max_initial_line_length setting in Elasticsearch (requires restart).
hi,
thank you for your answer.
I had already set it to 150kb. The result was that searches are now OK, these exceptions come from some other thing.
I’ll wait for 2.3.1 and see if this goes away.
Have you restarted all of your Elasticsearch nodes after changing the configuration setting for http.max_initial_line_length?
yes I have. I had first missed one server, but fixed that later, too. (but before the time from which the log snippets are from)
It seems that the ES is right now not able to merge the indices after cycling the write active index.
