Could not update field graph data errors
Hi. New to graylog. I’ve had this problem on both the VM and the Ubuntu package install. I am pretty sure this has been seen by others and there is a simple resolution, but I do not know what it is.
I am getting syslog messages in.
I can see the messages in the search field and they update.
But I am constantly getting the message
Updating field graph data failed: Error: cannot GET http://x.x.x.x:9000/api/search/universal/relative/fieldjistogram?query=*&range=300&interval=minute&field=message&cardinality=false (500)
Seems like the 500 at the end is a service unavailable httpstatus.
I see this too, when I use a very long interval. I have a bit less than 10000 shards in ES, and looking at the last month works OK, but trying to use the whole data (about 8 months now) it fails like this.
You could try if you use a shorter time frame, if it starts to work. If so, this is probably some setting in ES (or ES node JVM size, or something completely different)
Do you have any error messages in the Elasticsearch log file?
In my case, the problem is this:
org.jboss.netty.handler.codec.frame.TooLongFrameException: An HTTP line is larger than 12288 by
tes.
I used
http.max_initial_line_length: 12kb
in the elasticsearch yml file in the ES nodes, after having this with the default 4kb.
I wonder what is the maximum number that is reasonable here.
Seems to mostly be this sort of thing:
[2017-08-09T06:55:50,378][DEBUG][o.e.a.s.TransportSearchAction] [H89-dk0] [graylog_0][1], node[H89-dk0aRPiPxFPkZGPHPw], [P], s[STARTED], a[id=ppZQdHoqQU6px12lDwgIew]: Failed to execute [SearchRequest{searchType=QUERY_THEN_FETCH, indices=[graylog_0], indicesOptions=IndicesOptions[id=38, ignore_unavailable=false, allow_no_indices=true, expand_wildcards_open=true, expand_wildcards_closed=false, allow_alisases_to_multiple_indices=true, forbid_closed_indices=true], types=[message], routing='null', preference='null', requestCache=null, scroll=null, source={
  "query" : {
    "query_string" : {
      "query" : "TCP_NC_MISS\\/404",
      "fields" : [ ],
      "use_dis_max" : true,
      "tie_breaker" : 0.0,
      "default_operator" : "or",
      "auto_generate_phrase_queries" : false,
      "max_determinized_states" : 10000,
      "allow_leading_wildcard" : false,
      "enable_position_increments" : true,
      "fuzziness" : "AUTO",
      "fuzzy_prefix_length" : 0,
      "fuzzy_max_expansions" : 50,
      "phrase_slop" : 0,
      "escape" : false,
      "split_on_whitespace" : true,
      "boost" : 1.0
  "aggregations" : {
    "gl2_filter" : {
      "filter" : {
        "bool" : {
          "must" : [
              "range" : {
                "timestamp" : {
                  "from" : "2017-08-09 11:40:50.373",
                  "to" : "2017-08-09 11:55:50.373",
                  "include_lower" : true,
                  "include_upper" : true,
                  "boost" : 1.0
          "disable_coord" : false,
          "adjust_pure_negative" : true,
          "boost" : 1.0
      "aggregations" : {
        "gl2_histogram" : {
          "date_histogram" : {
            "field" : "timestamp",
            "interval" : "1m",
            "offset" : 0,
            "order" : {
              "_key" : "asc"
            "keyed" : false,
            "min_doc_count" : 0
          "aggregations" : {
            "gl2_stats" : {
              "stats" : {
                "field" : "message"
org.elasticsearch.transport.RemoteTransportException: [H89-dk0][127.0.0.1:9300][indices:data/read/search[phase/query]]
Caused by: java.lang.IllegalArgumentException: Fielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.
