I’m running the latest Docker image of Graylog and using the GELF HTTP input. I’m running into a limitation with the request content size. I’m getting the error:
org.jboss.netty.handler.codec.frame.TooLongFrameException: HTTP content length exceeded 65536 bytes.
I found this past GH issue related to this error, so I figured I could override the default value of 64K by using GRAYLOG_MAX_CHUNK_SIZE.
I tried setting this env variable on the container, but it doesn’t seem to change the setting, so I started digging around in the Graylog Configuration code. I noticed that the config file doesn’t have max_chunk_size in there at all. Does this mean that it’s not possible to override the default value, or am I doing something wrong?
