Description of your problem
Does anyone know how I can log the logs from hp switches to graylog? Is there some documentation somewhere used by someone successfully?
Can you elaborate on what you’ve tried already? Is this an issue with Graylog itself, or something with your source? If it’s your source, my suggestion would be to look at HP’s documentation for how they expect folks to configure external logging.
Thanks for the reply. I have sorted my issue.
