How to upgrade Graylog 2.2 to 2.3?
Thank you very much.
Are you using the appliance or standalone systems?
I used OVA install on VMware.
Here is the documentation you need.
Oh… Thank you very much.
HanSolo71
@cherawich do post your results; it didn’t work for me so I am curious if it will work for you! Thank you!
What part didn’t work for you?
Sorry for update.
Now. Your how to it’s work.
I have never had major issues upgrading it.
The procedure works; no errors; versions print correctly afterwords; however ton of java errors effectively rendering the upgraded OVA unusable; only fix is to roll back to the pre-upgrade snapshot. I can repeat the process at will and the outcome is consistent; don’t know why- maybe a plugin or what not but if people are reporting success I will assume it’s something with my OVA…
What errors are you getting?
smooth for upgrade no error.
