HI all-
I’m just getting started with Docker-CE running on Ubuntu 18. Have a few containers up and running a things are going well. In my server I have a 500gb ssd, and a 500gb spin drive. Docker is setup on /var/lib/docker, so all my volumes get created there (which is on the SSD). I’m setting up a graylog logging container using the sample yml file, but I would like the volume to be stored on my spin drive which is mounted at /mnt/data. Can someone help point me in the right direction. Here is the snipet from the yml file that I think needs to be modified:
services:
mongodb:
image: mongo:3
volumes:
- mongo_data:/data/db
volumes:
mongo_data:
driver: local
