Dear community,
I have spend the last two nights and a great part of today to figure out, how to run Graylog 6 in a Docker environment. The official Graylog documentation was partly helpful, partly misleading. I will summarize my findings here. Hopefully, this will benefit others as well.
Background
I usually run my docker container in different docker networks to separate them from each other. (-> increase security) My containers have a public facing network (-> macvlan), others have only an internal network, not open to anybody else.
If you are interested, here is all you need to know - besides the official Docker networking documentation.
Portainer is a simple tool to manage your docker containers. It provides a handy user interface.
docker compose.yaml
Here is my docker stack compose.yaml. (change xxxx into your passwords)
# version: as May 2024 https://docs.docker.com/compose/compose-file/
# https://go2docs.graylog.org/current/downloading_and_installing_graylog/docker_installation.htm
services:
mongodb6:
image: mongo:6.0.14
container_name: mongodb6
hostname: mongodb6
environment:
- TZ=Europe/Zurich
restart: unless-stopped
#DB in share for persistence
volumes:
- type: bind
source: /home/uadmin/Docker/Graylog6/mongo_data/mongo_db
target: /data/db
- type: bind
source: /home/uadmin/Docker/Graylog6/mongo_data/mongo_configdb
target: /data/configdb
deploy:
resources:
limits:
memory: 500mb
networks:
backend2:
ipv4_address: 10.10.14.3
opensearch:
image: opensearchproject/opensearch:2.12.0
container_name: opensearch
hostname: opensearch
volumes:
- /home/uadmin/Docker/Graylog6/opensearch-data:/usr/share/opensearch/data
environment:
- "OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g"
- "bootstrap.memory_lock=true"
- "discovery.type=single-node"
- "action.auto_create_index= false"
- "plugins.security.ssl.http.enabled=false"
- "plugins.security.disabled=true"
# Can generate a password for `OPENSEARCH_INITIAL_ADMIN_PASSWORD` using a linux device via:
# tr -dc A-Z-a-z-0-9_@#%^-_=+ < /dev/urandom | head -c${1:-32}
- "OPENSEARCH_INITIAL_ADMIN_PASSWORD=xxxx"
- TZ=Europe/Zurich
ports:
- "9200:9200"
ulimits:
memlock:
hard: -1
soft: -1
nofile:
soft: 65536
hard: 65536
networks:
backend2:
ipv4_address: 10.10.14.4
graylog6:
image: graylog/graylog:6.0
container_name: graylog6
hostname: graylog6
domainname: internal
#journal and config directories in local NFS share for persistence
volumes:
- /home/uadmin/Docker/Graylog6/graylog_data:/usr/share/graylog/data
entrypoint: "/usr/bin/tini -- wait-for-it opensearch:9200 -- /docker-entrypoint.sh"
environment:
# - GRAYLOG_NODE_ID_FILE= "/usr/share/graylog/data/config/node-id"
- GRAYLOG_HTTP_BIND_ADDRESS=192.168.60.13:9000
- GRAYLOG_ELASTICSEARCH_HOSTS= http://opensearch:9200
- GRAYLOG_MONGODB_URI= mongodb://mongodb6:27017/graylog
# To make reporting (headless_shell) work inside a Docker container
- GRAYLOG_REPORT_DISABLE_SANDBOX=true
- GRAYLOG_PASSWORD_SECRET=xxxx
# Password: "admin"
- GRAYLOG_ROOT_PASSWORD_SHA2=xxxx
- GRAYLOG_HTTP_EXTERNAL_URI=http://192.168.60.13:9000/
- TZ=Europe/Zurich
deploy:
resources:
limits:
memory: 2gb
networks:
macvlan60:
ipv4_address: 192.168.60.13
backend2:
ipv4_address: 10.10.14.2
links:
- mongodb6:mongo
- opensearch
depends_on:
mongodb6:
condition: service_started
opensearch:
ports:
- "9000:9000/tcp"
# Beats
- "5044:5044/tcp"
# Syslog TCP
- "5140:5140/tcp"
- "1514:1514" #(e.g. Unifi)
- "1515:1515" #(e.g. Tasmota)
# Syslog UDP
- "5140:5140/udp"
# GELF TCP
- "12201:12201/tcp"
# GELF UDP
- "12201:12201/udp"
# Forwarder data
- "13301:13301/tcp"
# Forwarder config
- "13302:13302/tcp"
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_db:
mongo_configdb:
opensearch-data:
graylog_data:
driver: local
# Network specifications
networks:
macvlan60:
external: true
backend2:
internal: true
ipam:
driver: default
config:
- subnet: "10.10.14.0/24"
important inputs and differences to the official documentation
persistent data
The official documentation states, that the graylog container runs with the user 1100. On my host system, I called it graylog. In order to get the persistance to work, you need to change the owner of the folders and subfolders to this user. (I also did a sudo chmod -R 777..., not sure, of this is really necessary.)
Be aware, that opensearch is not running under that user. The opensearch folder need to be owned by the user 1000 (-> name uadmin in my case).
root@ubuntu:/home/uadmin/Docker/Graylog6# ls -lah
total 20K
drwxrwxrwx 5 graylog graylog 4.0K May 11 23:03 .
drwxrwxrwx 12 root root 4.0K May 11 20:38 ..
drwxrwxrwx 8 graylog graylog 4.0K May 12 20:18 graylog_data
drwxr-xr-x 4 graylog graylog 4.0K May 11 23:03 mongo_data
drwxrwxrwx 3 uadmin uadmin 4.0K May 11 23:40 opensearch-data
node-id
This file contains the node-id. It is automatically generated. In the official documentation, the path to this file is included as an environment variable .
This did not work for me. I had to remove this line. The same information will be provided by the graylog.conf.
graylog.conf
This is a file, you need to get from github. Follow the official documentation, Custom Configuration Files. Check the folder permissions to be sure, graylog can use it.
Graylog environment variables
The official documentation puts the environment variables for the Graylog container in brackets. I had to remove them. see compose.yaml above.
opensearch port 9200
Because of my docker network setup, you need to map the opensearch port 9200. Otherwise, graylog cannot reach opensearch.
entrypoint: “/usr/bin/tini – wait-for-it elasticsearch:9200 – /docker-entrypoint.sh”
In some of the official examples, it says elasticsearch:9200. I had to change this to opensearch:9200, as this is the name of the opensearch container.
Well, this is all I can remember. ![]()
Know, I have to find out, how to migrate my data from Graylog 5.2, MongoDB 5.0.13 and Elasticsearch 7.10.2 to the new containers…
