Docker-Compose file issue
I am currently trying to get Graylog running with Opensearch in a container. Unfortunately I always get an error that Opensearch is not reachable on port 9200. Can someone help me to find the error please?
No service is running on this port:
user@graylog:~/docker-graylog$ sudo ss -tulwn | grep 9200
user@graylog:~/docker-graylog$ sudo lsof -i :9200
When I start the Compose file, I get this:
-c86e8e2a20c9","connectionId":3,"connectionCount":2}}
mongodb_1     | {"t":{"$date":"2023-11-23T07:55:35.796+00:00"},"s":"I",  "c":"-",        "id":20883,   "ctx":"conn2","msg":"Interrupted operation as its client disconnected","attr":{"opId":206}}
mongodb_1     | {"t":{"$date":"2023-11-23T07:55:35.796+00:00"},"s":"I",  "c":"NETWORK",  "id":22944,   "ctx":"conn2","msg":"Connection ended","attr":{"remote":"172.19.0.4:47738","uuid":"b1507e08-903a-4717-a945-fcb9e5b96f0c","connectionId":2,"connectionCount":1}}
mongodb_1     | {"t":{"$date":"2023-11-23T07:55:35.796+00:00"},"s":"I",  "c":"NETWORK",  "id":22944,   "ctx":"conn1","msg":"Connection ended","attr":{"remote":"172.19.0.4:47728","uuid":"74a471ce-2905-4f2d-b84e-a1335acffcb9","connectionId":1,"connectionCount":0}}
graylog_1     | 2023-11-23 07:55:35,800 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - Connected to MongoDB version 5.0.22
graylog_1     | 2023-11-23 07:55:36,029 INFO : org.graylog2.plugin.system.FilePersistedNodeIdProvider - Node ID: 26de8f56-9a50-4063-ac92-47d15e85e9d6
graylog_1     | 2023-11-23 07:55:36,170 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:55:36,171 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #1
graylog_1     | 2023-11-23 07:55:41,173 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:55:41,174 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #2
graylog_1     | 2023-11-23 07:55:46,177 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:55:46,178 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #3
graylog_1     | 2023-11-23 07:55:51,180 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:55:51,181 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #4
graylog_1     | 2023-11-23 07:55:56,183 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:55:56,184 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #5
graylog_1     | 2023-11-23 07:56:01,187 ERROR: org.graylog2.storage.versionprobe.VersionProbe - Unable to retrieve version from Elasticsearch node: Failed to connect to opensearch/172.19.0.2:9200. - Connection refused.
graylog_1     | 2023-11-23 07:56:01,188 INFO : org.graylog2.storage.versionprobe.VersionProbe - Elasticsearch is not available. Retry #6
My Compose file is:
version: "3.8"
services:
  graylog:
    image: "graylog/graylog:5.1"
    hostname: "server"
    depends_on:
      - opensearch
      - mongodb
    entrypoint: "/usr/bin/tini -- wait-for-it opensearch:9200 -- /docker-entrypoint.sh"
    environment:
      GRAYLOG_NODE_ID_FILE: "/usr/share/graylog/data/config/node-id"
      GRAYLOG_PASSWORD_SECRET: "pepperandsaltsmellsgoodright"
      GRAYLOG_ROOT_PASSWORD_SHA2: "password"
      GRAYLOG_HTTP_BIND_ADDRESS: "0.0.0.0:9000"
      GRAYLOG_HTTP_EXTERNAL_URI: "http://localhost:9000/"
      GRAYLOG_ELASTICSEARCH_HOSTS: "http://opensearch:9200"
      GRAYLOG_MONGODB_URI: "mongodb://mongodb:27017/graylog"
    ports:
      - "5044:5044/tcp"  # Beats
      - "5140:5140/udp"  # Syslog
      - "5140:5140/tcp"  # Syslog
      - "5555:5555/tcp"  # RAW TCP
      - "5555:5555/udp"  # RAW TCP
      - "9000:9000/tcp"  # Server API
      - "12201:12201/tcp" # GELF TCP
      - "12201:12201/udp" # GELF UDP
      - "13301:13301/tcp" # Forwarder data
      - "13302:13302/tcp" # Forwarder config
      - "5514:5514/udp"   # Graylog UDP input for log forwarding
    volumes:
      - "/home/USER/docker-graylog/volumes/graylog_data:/usr/share/graylog/data/data"
      - "/home/USER/docker-graylog/volumes/graylog_journal:/usr/share/graylog/data/journal"
    restart: "on-failure"
    networks:
      - graylog-net
  mongodb:
    image: "mongo:5.0"
    volumes:
      - "/home/USER/docker-graylog/volumes/mongodb_data:/data/db"
    networks:
      - graylog-net
  opensearch:
    image: "opensearchproject/opensearch:2.4.0"
    environment:
      - "OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g"
      - "bootstrap.memory_lock=true"
      - "discovery.type=single-node"
      - "action.auto_create_index=false"
      - "plugins.security.ssl.http.enabled=false"
      - "plugins.security.disabled=true"
    ulimits:
      memlock:
        soft: -1
        hard: -1
      nofile:
        soft: 65536
        hard: 65536
    volumes:
      - "/home/USER/docker-graylog/volumes/os_data:/usr/share/opensearch/data"
    networks:
      - graylog-net
networks:
  graylog-net:
    driver: bridge
volumes:
  mongodb_data:
  os_data:
  graylog_data:
  graylog_journal:
Looks like Graylog connection issue, check is the Opensearch running and test using curl
curl -X GET https://opensearch:9200 -u 'admin:admin' --insecure
