Having issues connecting to mongodb
Hey all,
I’m new to graylog, but fairly knowledgable with docker compose. I’m attempting to follow the install instructions for docker compose with graylog. It sets up mongodb, opensearch, and graylog. Everything seems to start up fine, except that i can’t get graylog to connect to mongodb. I can connect via mongosh and MongoDB Compass just fine, no auth. What could be the issue here?
My error in dockge console:
graylog-graylog-1 | 22:31:13.694 [main] INFO org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #2
graylog-graylog-1 | 22:31:15.694 [main] INFO org.mongodb.driver.cluster - Waiting for server to become available for operation with ID 3. Remaining time: 30000 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=192.168.2.23:27017, type=UNKNOWN, state=CONNECTING, exception={com.mongodb.MongoSocketOpenException: Exception opening socket}, caused by {java.net.SocketTimeoutException: Connect timed out}}].
Here’s my compose file:
version: “3”
services:
MongoDB: mongo - Official Image | Docker Hub
mongodb:
image: mongo:6.0.14
volumes:
- /mnt/files/graylog/mongodb/db:/data/db
- /mnt/files/graylog/mongodb/mongod/mongod.conf:/etc/mongod.conf:ro
entrypoint:
- mongod
- --replSet
- graylogrepl
- --bind_ip
restart: on-failure
ports:
- 27017:27017
networks:
- graylog
opensearch:
image: opensearchproject/opensearch:2.12.0
environment:
- OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g
- bootstrap.memory_lock=true
- discovery.type=single-node
- action.auto_create_index=false
- plugins.security.ssl.http.enabled=false
- plugins.security.disabled=true
- OPENSEARCH_INITIAL_ADMIN_PASSWORD=
ports:
- 9200:9200
ulimits:
memlock:
hard: -1
soft: -1
nofile:
soft: 65536
hard: 65536
restart: on-failure
networks:
- graylog
Graylog: Graylog graylog/
graylog:
hostname: pyra
image: graylog/graylog:6.0
# To install Graylog Open: “graylog/graylog:6.0”
depends_on:
mongodb:
condition: service_started
opensearch:
entrypoint: /usr/bin/tini – wait-for-it opensearch:9200 – /docker-entrypoint.sh
environment:
#- GRAYLOG_NODE_ID_FILE= /usr/share/graylog/data/config/node-id
- GRAYLOG_REPORT_DISABLE_SANDBOX=true
#- GRAYLOG_MONGODB_URI=mongodb://graylog:vWGzncmBe9"@mongodb:27017/graylog
#“8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918”
#- GRAYLOG_HTTP_EXTERNAL_URI= “http:// dockage:9000/”
ports:
- 39000:9000/tcp
- 5044:5044/tcp
- 5140:5140/tcp
- 5140:5140/udp
- 12201:12201/tcp
- 12201:12201/udp
- 13301:13301/tcp
- 13302:13302/tcp
volumes:
- /mnt/files/graylog/data:/usr/share/graylog/data/
- /mnt/files/graylog/journal:/usr/share/graylog/data/journal
restart: on-failure
networks:
graylog:
driver: bridge
Hey @dexxfm
have you tired opening up this port ?
never mind i see you did.
EDIT: have you tried this configuration here?
I found the issue. during my edits i apparently deleted the network attribute from the graylog service. :frowning: i’m an idiot, but at least i learned something!
LMAO it happens @dexxfm
glad you found the issue.
