Docker Graylog connect in single MongoDB but not in Replica set
I’m having problems connecting a Graylog docker to a MongoDB replica set.
I’ve built a MongoDB replica set with 3 servers (1 primary - 2 secondary). But when I execute the command “docker run”, the installation did not connect to MongoDB correctly. I’ve made a test with a single MongoDB and the same “docker run” of Graylog and it worked.
sudo docker run --name mongo -v /opt/open/mongodb/data:/data/db -v /opt/open/mongodb/mongod.conf:/etc/mongod.conf.orig -p 27017-27019:27017-27019 -d mongo --smallfiles
sudo docker run -d -e TZ=America/Sao_Paulo --restart always --name graylog --link mongo -p 80:9000 -p 514:514 -p 514:514/udp -p 12201:12201 -p 12201:12201/udp -v /opt/open/graylog:/usr/share/graylog graylog/graylog:3.0 && sudo docker logs -f graylog &
2019-04-04 15:15:04,951 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
But when I execute the same command with a replica set configured, I get this message:
2019-04-04 15:58:01,220 ERROR: org.graylog2.filters.ExtractorFilter - Unable to load extractors for all inputs
com.mongodb.MongoQueryException: Query failed with error code 13 and error message ‘command find requires authentication’ on server mongo:27017
I’ve configured the connection string with user and password created on admin database, but nothing happened.
mongodb_uri = mongodb://admin:admin@server-1:27017,server-2:27017,server-3:27017/admin?replicaSet=rs_graylog_sistemas
I don’t know what else I can do. I’m trying this for months. I’ve already read tha manual and site many times, but nothing helped.
how did you configured in Graylog what MongoDB the Graylog should use?
Did you mount a configuration?
Did you use environment variables?
This is the configuration of MongoDB in Graylog.conf
mongodb_uri = mongodb://admin:admin@server-3:27017,server-2:27017,server-3:27017/admin?replicaSet=rs_graylog_sistemas
I didnt mount a configuration. I use only “docker run” with the variables. It was mentioned above.
how did you handover this configuration string to Graylog exactly?
Check
grep mongodb_uri /etc/graylog/server/server.conf
And
mongo -u admin -p admin admin
// Are you sure you use the user admin with password admin, and you store the graylog related information in admin database?
This string is configured in /opt/open/graylog/graylog.conf.
mongodb connection string
#See https://docs.mongodb.com/manual/reference/connection-string/ for details
#mongodb_uri = mongodb://mongo/graylog
#mongodb_uri = mongodb://server-1 (used to test the connection - not successful)
#Authenticate against the MongoDB server
#mongodb_uri = mongodb://grayloguser:secret@mongo:27017/graylog
#mongodb_uri = mongodb://root:admin20@server-1:27017/admin (used to test the connection - not successful)
#Use a replica set instead of a single host
#mongodb_uri = mongodb://grayloguser:secret@mongo:27017,mongo:27018,mongo:27019/graylog
Both users (root and admin) are configured with role “root” from ADMIN database.
#From Check
The mongodb_uri string is above.
#From And
From Graylog Server
root@server-2:/# mongo -u admin -p admin admin
MongoDB shell version v4.0.5
connecting to: mongodb://127.0.0.1:27017/admin?gssapiServiceName=mongodb
Implicit session: session { “id” : UUID(“d3d01022-d638-4226-bfe4-8877b4c8ab8e”) }
MongoDB server version: 4.0.5
Welcome to the MongoDB shell.
For interactive help, type “help”.
For more comprehensive documentation, see
http://docs.mongodb.org/
Questions? Try the support group
http://groups.google.com/group/mongodb-user
Server has startup warnings:
2019-04-04T14:00:24.450-0300 I STORAGE [initandlisten]
2019-04-04T14:00:24.450-0300 I STORAGE [initandlisten] ** WARNING: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine
2019-04-04T14:00:24.450-0300 I STORAGE [initandlisten] ** See Production Notes for Self-Managed Deployments - Database Manual - MongoDB Docs
2019-04-04T14:00:25.888-0300 I CONTROL [initandlisten]
2019-04-04T14:00:25.888-0300 I CONTROL [initandlisten] ** WARNING: /sys/kernel/mm/transparent_hugepage/enabled is ‘always’.
2019-04-04T14:00:25.888-0300 I CONTROL [initandlisten] ** We suggest setting it to ‘never’
2019-04-04T14:00:25.888-0300 I CONTROL [initandlisten] ** WARNING: /sys/kernel/mm/transparent_hugepage/defrag is ‘always’.
Enable MongoDB’s free cloud-based monitoring service, which will then receive and display metrics about your deployment (disk utilization, CPU, operation statistics, etc).
The monitoring data will be available on a MongoDB website with a unique URL accessible to you
and anyone you share the URL with. MongoDB may use this information to make product
improvements and to suggest MongoDB products and deployment options to you.
To enable free monitoring, run the following command: db.enableFreeMonitoring()
To permanently disable this reminder, run the following command: db.disableFreeMonitoring()
rs_graylog_sistemas:SECONDARY>
From MongoDB Master Server
root@server-1:/# mongo -u admin -p admin admin
Implicit session: session { “id” : UUID(“140e4d98-d485-44f7-b02a-25f8b9278654”) }
2019-04-04T14:00:18.381-0300 I STORAGE [initandlisten]
2019-04-04T14:00:18.381-0300 I STORAGE [initandlisten] ** WARNING: Using the XFS filesystem is strongly recommended with the WiredTiger storage engine
2019-04-04T14:00:18.381-0300 I STORAGE [initandlisten] ** See Production Notes for Self-Managed Deployments - Database Manual - MongoDB Docs
2019-04-04T14:00:19.540-0300 I CONTROL [initandlisten]
2019-04-04T14:00:19.540-0300 I CONTROL [initandlisten] ** WARNING: /sys/kernel/mm/transparent_hugepage/enabled is ‘always’.
2019-04-04T14:00:19.540-0300 I CONTROL [initandlisten] ** We suggest setting it to ‘never’
2019-04-04T14:00:19.540-0300 I CONTROL [initandlisten] ** WARNING: /sys/kernel/mm/transparent_hugepage/defrag is ‘always’.
rs_graylog_sistemas:PRIMARY>
How did you handover the configuration your wrote to Graylog?
Hw should the docker container take the configuration from /opt/open/graylog/graylog.conf?
Check the Documentation again on the confinguration files in docker:
http://docs.graylog.org/en/3.0/pages/installation/docker.html#custom-configuration-files
I’ve made some modifications on the command and worked well. The MongoDB replica set is up and connected.
sudo docker run -d -e TZ=America/Sao_Paulo --restart always --name graylog --link mongo -p 80:9000 -p 514:514 -p 514:514/udp -p 12201:12201 -p 12201:12201/udp -v /opt/open/graylog/graylog.conf:/usr/share/graylog/data/config/graylog.conf graylog/graylog:3.0 && sudo docker logs -f graylog &
But it still doesn’t connect to the ELS.
2019-04-17 16:21:06,096 INFO : org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical - Cluster not connected yet, delaying index field type initialization until it is reachable.
2019-04-17 16:21:06,110 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn’t read cluster health for indices [graylog_*] (n/a)
2019-04-17 16:21:06,115 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2019-04-17 16:21:06,115 INFO : org.graylog2.periodical.IndexRetentionThread - Elasticsearch cluster not available, skipping index retention checks.
2019-04-17 16:21:06,307 INFO : org.graylog2.migrations.V20161130141500_DefaultStreamRecalcIndexRanges - Cluster not connected yet, delaying migration until it is reachable.
2019-04-17 16:21:20,820 INFO : org.graylog2.periodical.IndexRangesCleanupPeriodical - Skipping index range cleanup because the Elasticsearch cluster is unreachable or unhealthy
2019-04-17 16:45:05,900 WARN : org.graylog2.initializers.BufferSynchronizerService - Elasticsearch is unavailable. Not waiting to clear buffers and caches, as we have no healthy cluster.
I can connect and check the settings on ELS cluster.
[user@server-2 graylog]$ curl ‘10.128.20.21:9200/_cat/health?v’
epoch timestamp cluster status node.total node.data shards pri relo init unassign pending_tasks max_task_wait_time active_shards_percent
1555530558 19:49:18 graylog_prd_1 green 3 3 0 0 0 0 0 0 - 100.0%
[user@server-2 graylog]$ curl ‘10.128.20.21:9200/_cat/nodes?v’
ip heap.percent ram.percent cpu load_1m load_5m load_15m node.role master name
10.128.20.23 12 57 0 0.14 0.08 0.06 mdi - els3
10.128.20.22 12 61 0 0.21 0.13 0.09 mdi - els2
10.128.20.21 13 60 0 0.01 0.04 0.05 mdi * els1
[user@server-2 graylog]$ telnet 10.128.20.23 9300
Trying 10.128.20.23…
Connected to 10.128.20.23.
Escape character is ‘^]’.
telnet> quit
Connection closed.
[user@server-2 graylog]$ telnet 10.128.20.23 9200
^L^]
telnet> quit
Connection closed.
What am I missing?
what setting do you have in your graylog.conf ? The default connects to localhost
I’m using this line:
elasticsearch_hosts = http://els1:9300,http://els2:9300,http://els3:9300
It’s the same configuration I use on the other graylog structure, but without docker. I use RPM files for everything
1 Graylog installed with MongoDB local and 3 ELS in cluster mode in another network.
are the elasticsearch reachable with that name in your docker setup?
Yes.
[user@server-2 ~]$ sudo docker exec -it graylog curl ‘els1:9200/_cat/nodes?v’
10.128.20.23 16 57 0 0.00 0.03 0.05 mdi - els3
10.128.20.22 20 62 0 0.01 0.03 0.05 mdi - els2
10.128.20.21 20 61 0 0.05 0.04 0.05 mdi * els1
[user@server-2 ~]$ sudo docker exec -it graylog curl ‘els1:9200/_cat/health?v’
1555615571 19:26:11 graylog_prd_1 green 3 3 0 0
