Sorry for my bad english !
Here is the version of different packages what I use :
elasticsearch-6.8.2-1.noarch
graylog-server-3.1.1-1.noarch
graylog-3.1-repository-1-1.noarch
mongodb-org-tools-3.6.14-1.el6.x86_64
mongodb-org-3.6.14-1.el6.x86_64
mongodb-org-shell-3.6.14-1.el6.x86_64
mongodb-org-server-3.6.14-1.el6.x86_64
mongodb-org-mongos-3.6.14-1.el6.x86_64
I use graylog to collect log from OSSEC SERVER in CEF format
When I want to search severity field with arithemtics comparaison such as “<, <=, >=,>”.
I note the wrong result, exemple : “source: AND severity:<7” , results are severity 5,7,10 …
After find type of severity field in ES, I noted is “keyworld” and not “long”
My question is, how can I modify type of this field for current index and new index ?
Otherwise, is it possible to use Pipeline or GROK or something else to modify in realtime the type of this field ?
Regards,
KirM
