Hi Team
Actually, we have some sensitive data in logs and want to mask it. Using Graylog appender, we are sending log data to graylog. Can you please let me know how to mask sensitive log data on Graylog without putting a load on my application server.
Thanks Srumith.
You can use Streams to restrict access to certain log messages to specific users or groups: http://docs.graylog.org/en/2.3/pages/streams.html
Can I use extractors, which generally parse the log-data and modify the data in the required format?
Sure. Or use the processing pipelines.
ok fine, Thank you
