I don’t yet have public IPs that can be mapped by maxmind geoip db(R1).
What is the solution to still be able to display private IP in map ?
Do I have to create my own geoip db ?
Who do you guys deal with this missed feature ?
hej @tjyang
with the new lookup tables you easily create your own geoid DB that contains the Information from your Network and add this as additional source.
That way you can run the maxmind geoip Lookups and your own in just one pipeline rule
with kind regards
Jan
@jan, looking forward to try out lookup table in my 2.3.1 graylog cluster. Thanks for the pointer.
