Good Morning,
I want to ask , what are the step to do a geolocalisation from IP adress in graylog 3 ?
Thank you
Good Morning,
Thank you
the problem , it hasn’t more details ,
Best regards
you might want to clarify what isn’t clear for you. With that given we are able to help you.
It’s work but when the ip adress is private , the database doesn’t give the latitude and longitude .
What can I do for the private IP
If there is a private IP , they doesn’t show the map because the database can’t translate the IP adress to map data (longitude and latitude )
Thank you
How should that work? I guess you have millions of hosts with 192.168.0.1 - whoes latitude and longitude you want in that?
create your own database for your network that actually contain the information that fit to your network and use that in a lookup table!
Thanks ,
I think IT’s a good Idea to add database for the private adresse ( like 192.168.*** or 172.**** or 10.*** )
but how I can add all these IP adresse one by one , or what is the other way ?
thank you
google just showed me this: https://github.com/threatstream/mhn/wiki/Customizing-Maxmind-IP-Geo-DB-for-Internal-Networks
Disclaimer: I NEVER MADE THIS MYSELF NOT IS THAT SOMETHING I HAVE WRITTEN
thank you very much for your help
