How to export stream rules?
I currently use Graylog 3.3.4+279ef2c, in a VM, however I’d like to move to a docker install. I have about 200 rules defined for a stream, how can I export these and import them into the docker install?
Thanks!
Use content packs. Create one on the VM install containing the streams and then import it in the Docker install
You can use the REST API as well.
https://graylog.contoso.com:1337/api/api-browser/#!/StreamRules
Thank you both I couldn’t get the api link to work, but the content packs are exactly what I was looking for.
