How to do graph with extracted field value on y-axis
I created an extractor for response_time on a tcp port. Next I would like to create a chart, with the Y-Axis being the response time (from the extracted field, between 0 and 120) , and X-axis the time/date of the message.
When I create a chart from my search, the Y-axis becomes the number of messages containing my search result, and I can’t find way to change that to the field value response_time.
Customizing the chart does not allow me to change the Y-axis.
Surely this must be something simple, but how can I create the graph with nummeric field_value in the Y-axis?
(graylog 2.4)
in that Graylog version that is not possible.
Hi Jan,
Thanks for your quick reply. You’ve helped us before, we appreciate it!
Yet another reason to upgrade :slight_smile:
