Extracted number from syslog message unusable
(OVA Graylog v2.4.3+2c41897)
I’m trying to display values (cpu) throught an extractor from a syslog message in order to display it on a chart.
The extractor seems to works fine : I can get the cpu value with the extractor, and the value is well displayed as a field on my stream.
But when I try to display it on a chart (value max, min, mean …), the value is always zéro.
When I display the statistics of my extracted field, the displayed values are “Nan” (except total & cardinality)
It look like my my extracted field value is not seen as a number.
I have tried with the extractors substring, regexp (both with number conversion) and grok, with the same result.
Any idea about how I can display this extracted value ?
Folowing due to simular problem.
is the value a single number that is saved in one field? The statistical function/display is only available if the value is saved as number.
You could force the field with the extracted field as number via elasticsearch index template: http://docs.graylog.org/en/2.4/pages/configuration/elasticsearch.html#custom-index-mappings
Yes, the field is a single number.
The value is currently extracted using a regexp extractor, then converted to a numeric value using the extractor option.
is that also saved as a number in Elasticsearch? Because if the dynamic mapping it might be saved as a string. ( https://www.elastic.co/guide/en/elasticsearch/guide/2.x/dynamic-mapping.html ).
To correct that, rotate your index and/or create a custom mapping forcing that field to be a number
Thank you.
It’s working by forcing the type to integer over a custom mapping of the field in Elasticsearch.
