How to collect custom logs?
Hi everyone, first of all thanks for your support my question is.
How can i collect logs from custom location in windows? for example, audit logs for MSSQL, or another application.
Here’s my actual config.
# Needed for Graylog fields_under_root: true fields.collector_node_id: ${sidecar.nodeName} fields.gl2_source_collector: ${sidecar.nodeId}
output.logstash:
hosts: [“10.X.X.X:5044”]
path:
tags:
  • windows
    winlogbeat:
    event_logs:
    • name: Application
    • name: System
    • name: Security
Thanks in advice
If you do not have the logs in the Windows events, you must use Filebeat or Nxlog.
Winlogbeat only supports Windows events. Your MSSQL server is able to log the Audit to the Windows events.
as winlogbeat is only getting the messages from windows event log, you need to configure filebeat to get specific logfiles.
thanks for the answer, i try to configure filebeat but without results.
this is my config
output.logstash:
hosts: [“10.0.1.65:5044”]
path:
data: C:\Program Files\Graylog\sidecar\cache\filebeat\data
tags:
  • windows
    filebeat.inputs:
    type: log
    enabled: true
    paths:
    • C:\ProgramData\Veeam\Endpoint*log
and the logs
2019-09-26T16:56:03.187-0500 INFO instance/beat.go:544 Home path: [C:\Program Files\Graylog\sidecar] Config path: [C:\Program Files\Graylog\sidecar] Data path: [C:\Program Files\Graylog\sidecar\cache\filebeat\data] Logs path: [C:\Program Files\Graylog\sidecar\logs] 2019-09-26T16:56:03.203-0500 INFO instance/beat.go:551 Beat UUID: 3900d37a-da41-43dd-863e-93b0938caaa8 2019-09-26T16:56:03.203-0500 INFO [beat] instance/beat.go:768 Beat info {"system_info": {"beat": {"path": {"config": "C:\\Program Files\\Graylog\\sidecar", "data": "C:\\Program Files\\Graylog\\sidecar\\cache\\filebeat\\data", "home": "C:\\Program Files\\Graylog\\sidecar", "logs": "C:\\Program Files\\Graylog\\sidecar\\logs"}, "type": "filebeat", "uuid": "3900d37a-da41-43dd-863e-93b0938caaa8"}}} 2019-09-26T16:56:03.203-0500 INFO [beat] instance/beat.go:777 Build info {"system_info": {"build": {"commit": "e193f6d68b25b7ddbe3a3ed8d60bc07fea1ef800", "libbeat": "6.4.2", "time": "2018-09-26T12:41:59.000Z", "version": "6.4.2"}}} 2019-09-26T16:56:03.203-0500 INFO [beat] instance/beat.go:780 Go runtime info {"system_info": {"go": {"os":"windows","arch":"amd64","max_procs":4,"version":"go1.10.3"}}} 2019-09-26T16:56:03.214-0500 INFO [beat] instance/beat.go:784 Host info {"system_info": {"host": {"architecture":"x86_64","boot_time":"2019-09-09T17:46:29.73-05:00","hostname":"SqlServer232","ips":["fe80::d60:3acc:e66d:6806/64","192.168.0.232/24","::1/128","127.0.0.1/8","fe80::5efe:c0a8:e8/128"],"kernel_version":"6.3.9600.18589 (winblue_ltsb.170204-0600)","mac_addresses":["00:15:5d:07:59:1f","00:00:00:00:00:00:00:e0"],"os":{"family":"windows","platform":"windows","name":"Windows Server 2012 R2 Standard","version":"6.3","major":3,"minor":0,"patch":0,"build":"9600.18619"},"timezone":"CDT","timezone_offset_sec":-18000,"id":"f893ae12-cf30-4934-8b44-4e24a91706d1"}}} 2019-09-26T16:56:03.214-0500 INFO instance/beat.go:273 Setup Beat: filebeat; Version: 6.4.2 2019-09-26T16:56:03.215-0500 INFO pipeline/module.go:98 Beat name: SqlServer232 2019-09-26T16:56:03.217-0500 ERROR instance/beat.go:743 Exiting: no modules or inputs enabled and configuration reloading disabled. What files do you want me to watch?
