How to access missing web gui elements?
I’m struggling with the correct terminology for my question, so forgive me if I’m not clear.
I recently installed Graylog and got a few inputs working. Normally when I go to see the messages from a particular input, there is a Histogram display on the right, and a couple of other “proto?” graphs. Also some options for revisualizing data as graphs, etc.
I closed a few of the items and now I can find no way to get them back. Is there a way to reset the initial view of http://myserverip:9000/search to the installed defaults?
it is always a question of the version of Graylog you are using - but the current release will be put back to defaults once you log out and in again.
