How Graylog set alert field value to true or false
Hi All,
We are using Graylog 3.1.1 with Elasticsearch 6.8.1 & Mongo 3.6.14. I am trying to setup alerts based on the event condition.
I am receiving IIS logs to graylog and I am setting iis_Access_Responsecode:>=500 in event filter condition with aggregation group by field as iis_Access_SiteName and if my events count is > than 5 alerts will be triggered.
Yes I am able to see alerts triggered based on the event definition and messages are recorded to the “All Events” stream. But in the all events stream I am getting two types of messages and the field “alert” has two values,
  1. alert=false
  2. alert=true
Below is the sample message with alert= false
    "_source" : {
      "id" : "01DMFWQERB48FSDMVZTNSYD",
      "event_definition_type" : "aggregation-v1",
      "event_definition_id" : "5d76470a026d94693",
      "origin_context" : null,
      "timestamp" : "2019-09-11 10:08:14.276",
      "timestamp_processing" : "2019-09-11 10:08:28.427",
      "timerange_start" : "2019-09-11 10:03:22.453",
      "timerange_end" : "2019-09-11 10:08:22.452",
      "streams" : [
        "000000000000000000000002"
      "source_streams" : [
        "5d76240b945248b2f"
      "message" : "500_ErrorCodes: abc.graylog.com- count()=12.0",
      "source" : "graylog3-helm-0.graylog3-helm-svc.cluster.local",
      "key_tuple" : [ ],
      "key" : "",
      "priority" : 2,
      "alert" : false,
      "fields" : { }
Below is the sample message with alert=true
    "_source" : {
      "id" : "01DMFN7WGAEB3TXTPRK",
      "timestamp" : "2019-09-11 07:55:33.233",
      "timestamp_processing" : "2019-09-11 07:57:38.243",
      "timerange_start" : "2019-09-11 07:52:22.452",
      "timerange_end" : "2019-09-11 07:57:22.451",
      "streams" : [
        "5d76240b945248b2f"
      "message" : "500_ErrorCodes: def.graylog.com - count()=14.0",
      "source" : "graylog3-helm-0.graylog3-helm.svc.cluster.local",
      "key_tuple" : [ ],
      "key" : "",
      "priority" : 2,
      "alert" : true,
      "fields" : { }
I am not able to understand how the graylog sets the value of alert field to true or false
I didn’t find much information on the alerts documentation
Kindly share your thoughts and help us to understand the alerts concept.
Regards,
Ganeshbabu R
If we add the notification in the event definition then alert field value set as “True” in the message.
