Graylog 6.0 Triggering alerts when conditions not met
I have recently installed Graylog 6.0 (6.0.6+4aa664f, codename Noir) and I am working to migrate over from and old graylog 3.x instance. I currently have the old graylog instance sending logs to the new one via a GELF output. I exported a content pack and have it successfully importing on the new server. Everything works as expected except there are alerts being triggered for most of my event definitions even though the conditions are not being met to trigger an alert. When looking at Event Definition Filter & Aggregation tab it reports no messages with the current search criteria but if I go back to alerts I can see that it is triggered with thousands of results. Most of these are streams that are generally empty and should trigger an alert if there are any results.
  • OS Information:
    rocky 9
  • Package Version:
creating a alert for a stream has the same false positive alerts
any ideas why this is happening?
to provide an update I did find the problem is only present when using “Aggregation of results reaches a threshold”. If use “Filter has results” for the event having results (aka no results expected) then everything works normally but if i have the aggregation selected and Count()>x (even if x is 0) then i get false positives. Has any functionality changed with the “Aggregation of results reaches a threshold” function? This problem is present in event definitions i created in the current version or carried over with a content pack. Anyone know if there is a better way to use the threshold feature?
Further update:
I was able to resolve this problem by setting a value for “Group by Field(s)”. For the ones where I didn’t need a group I just picked something like loglevel that is the same on every log so that it would still trigger any time the threshold was met. I’m still not sure why the change in behavior but it appears to be an issue for newly created event definitions as well as the ones I imported.
I think you may be running into an OS 2.16 issue.
Check out this for a discussion and workaround:
Thanks, not sure how i missed all of this in my searches
