How do I post curl commands in graylog?
I recently got started with graylogs and I understand that we can get logs for a particular application using the GUI provided after we specify the below parameters -
  • Relative/Absolute time
  • Search query
    and then we can download the output as .csv file.
I have already tried this method out, and the problem I faced was that, If I had to obtain logs for every 1 hour interval for a period of 3 days, I had to manually change the time and download the .csv files and arrange it.
For now, I wish to use a different method to obtain the logs. I want to use curl requests as the input instead of the GUI.
My Question Is - How/Where do we specify curls instead of using the GUI to get the logs?
I am not much of an expert in graylogs so I didn’t see any option related curls. I already know how to write the curls for graylogs thanks to a comment made by Jan Doberstein, link to post below -
Where do I find the ‘Export API’ mentioned in the comment (in the post above) ?
Im currently using MacOS. (I don’t think that’s useful, but ok.)
Thanks! Looking forward to some help!
Hello && Welcome @sruju333
Navigate to System/Nodes → API browser
Thank you very much.
‘Export API’ was a confusing term for a beginner.
I was able to find the ‘Export API’ which I needed after accessing the base_URL/api/api-browser endpoint (same as above) and then going to /search/universal/absolute/export API.
This partially solves my problem, will post another question if the need arises. Thank you once again.
Awesome, glad to help. If you could mark this as resolved this will help future search’s :+1:
