How change Index rotate by date
Hello Community Graylog,
Is It possible to configure the graylog servers to rotate
the elasticsearch indexes by date instance of sequence number?
Ex.: Client1_MMDDYYYY
Is It possible? How?
Thanks!
Short answer: no.
Long answer: no. why would you want to?
I’d like to configure an easier way to reopen the index.
You did read that this issue is closed as feature issue - which means, it will not be implemented.
