Hi Support, I have a requirement to ship logs for different applications on a Single Graylog system. For Each application, I will be needing different users, specific to the applications. So, could I provide rights to users specific to the application. Say User-A can access only logs of application A only.
this is possible, just give users only the option to see their stream of messages.
Yes. Use streams to ensure logs for application A go to stream A, logs for application B go to stream B. Then you can create a role that allows read access to stream A, then a role that allows read access to stream B, and then you can assign these roles to individual users.
