Histogram search timeframe not updating
When changing the search period (with or without pressing play) the histogram window does not reflect the expected time-period but instead remains at the “5 minute” period (see attached image).
Running Graylog 3.0.2+1686930 on 3.217.218.53
Oracle Corporation 1.8.0_212 on Linux 4.15.0-1043-aws
Thank you
I’d go for a hard refresh on the page, probably just a glitch in the UI
Changing the search period does not refresh the search. You need to manually launch it.
you mind looking in github if that is a know isssue and if not raise one?
thx
Thank you Jan, I searched the issues carefully and did not find a matching issue, so I created a new ticket for the same:
A hard refresh did not help unfortunately, but I did discover that this is only effecting “Relative” time-frames. The “Keywords” and Absolute date ranges work as expected.
Indeed - unfortunately clicking play / resubmitting the search updates the search results but the histogram does not update.
I did notice that changing to “Keyword” or “Absolute” date ranges do work as expected - it is only the relative terms that do not eg “last week” etc.
