Having troubles with Office 365 (again ^^')
Dear users of the Graylog Community, hi !
To follow-up to this thread I posted a while ago, I still have issues with Office 365 implementations.
I reinstalled a fresh Graylog Server with a small business licence in order to resolve the numerous issues I was having with my old server.
This time, I have SSL/TLS enabled. That solved nearly all the errors I was getting with the old server, like mail issues and some Office 365 related stuff.
I still have these erros in the logs, maybe some of you have already encountered theses and will provide me some useful tips ? :stuck_out_tongue:
My config : Debian 11, latest Graylog 4.3.7, small business licence, enterprise plugins, integration plugins, enterprise integration plugins.
Here are the errors :
2022-09-27T17:14:17.874+02:00 ERROR [O365Client] O365 API request threw exception [timeout.] on attempt [22].
	at okhttp3.internal.http2.Http2Stream$StreamTimeout.newTimeoutException(Http2Stream.java:678) ~[graylog.jar:?]
	at okhttp3.internal.http2.Http2Stream$StreamTimeout.exitAndThrowIfTimedOut(Http2Stream.java:686) ~[graylog.jar:?]
	at okhttp3.internal.http2.Http2Stream.takeHeaders(Http2Stream.java:154) ~[graylog.jar:?]
	at okhttp3.internal.http2.Http2ExchangeCodec.readResponseHeaders(Http2ExchangeCodec.java:136) ~[graylog.jar:?]
	at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[graylog.jar:?]
	at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[graylog.jar:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[graylog.jar:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[graylog.jar:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[graylog.jar:?]
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[graylog.jar:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[graylog.jar:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[graylog.jar:?]
	at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:204) ~[graylog.jar:?]
	at org.graylog.enterprise.integrations.office365.external.O365Client.lambda$doCall$5(O365Client.java:159) ~[?:?]
	at com.github.rholder.retry.AttemptTimeLimiters$NoAttemptTimeLimit.call(AttemptTimeLimiters.java:78) ~[graylog.jar:?]
	at com.github.rholder.retry.Retryer.call(Retryer.java:160) [graylog.jar:?]
	at org.graylog.enterprise.integrations.office365.external.O365Client.doCall(O365Client.java:158) [graylog-plugin-enterprise-integrations-4.3.7.jar:?]
	at org.graylog.enterprise.integrations.office365.external.O365Client.listAvailableContent(O365Client.java:120) [graylog-plugin-enterprise-integrations-4.3.7.jar:?]
	at org.graylog.enterprise.integrations.office365.O365PollerTask.doRun(O365PollerTask.java:97) [graylog-plugin-enterprise-integrations-4.3.7.jar:?]
	at org.graylog.enterprise.integrations.office365.O365PollerTask.run(O365PollerTask.java:52) [graylog-plugin-enterprise-integrations-4.3.7.jar:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?]
	at java.lang.Thread.run(Thread.java:833) [?:?]
This seems quite weird and wasn’t an error I already have before. Same goes for this :
2022-09-27T17:16:11.392+02:00 WARN  [O365Client] Client Error: [{"error":{"code":"AF20055","message":"Start time and end time must both be specified (or both omitted) and must be less than or equal to 24 hours apart, with the start time prior to  end time and start time no more than 7 days in the past. StartTime:2022-09-27T15:16:11, EndTime:2022-09-27T15:16:11"}}]
2022-09-27T17:16:11.393+02:00 WARN  [O365PollerTask] Error fetching manifest for Content Type [DLP_ALL]: [Cannot invoke "java.util.Collection.toArray()" because "c" is null.]
java.lang.NullPointerException: Cannot invoke "java.util.Collection.toArray()" because "c" is null
	at java.util.ArrayList.addAll(ArrayList.java:670) ~[?:?]
	at org.graylog.enterprise.integrations.office365.external.O365Client.listAvailableContent(O365Client.java:121) ~[graylog-plugin-enterprise-integrations-4.3.7.jar:?]
Maybe it’s normal and/or not bad at all, but I don’t like to see red lines and errors in my log, I think you feel the same ^^
Many thanks in advance for your answers,
Have a good day :slight_smile:
Hey @gmorin
Sorry to see your still having issues, first I havent used 0365 input but from what I see from the logs and taking a guess is this.
This seams to be a connection issue, I have seen this when using TCP/TLS or perhaps firewall.
ERROR [O365Client] O365 API request threw exception [timeout.] on attempt [22].java.net.SocketTimeoutException: timeout
Did you check date time on host and client?
WARN [O365Client] Client Error: [{“error”:{“code”:“AF20055”,“message”:“Start time and end time must both be specified (or both omitted)
StartTime:2022-09-27T15:16:11, EndTime:2022-09-27T15:16:11”}}]
Just guessing here, but I think those error/s are producing these warnings.
2022-09-27T17:16:11.393+02:00 WARN  [O365PollerTask] : [Cannot invoke "java.util.Collection.toArray()" because "c" is null.]
Hi @gsmith,
I just reconfigured my NTP client, hope it’ll solve the issue !
Thanks for your fast answer :wink:
No problem @gmorin this is just a strange issue, sorry you have to go through all this.
