Error when trying to add an additional Office 365 input
Getting the following error on the portal when trying to add an additional Office365 input at the content subscription page:
Cannot invoke “java.util.List.stream()” because the return value of “org.graylog.enterprise.integrations.office365.external.O365Client.getSubscriptions()” is null.
Tested on another Office 365 tenant, same issue - We’ve previously added many others without issue
Self-Hosted Linux (ubuntu) (single instance) - Graylog Enterprise Server version 4.3.7-1. Was on previous version, updated to latest as part of troubleshooting
  • OS Information:
Ubuntu 18.4.6
  • Package Version:
    No errors on the portal besides the listed one when adding an additional input
Using this type of input here I believe you need Graylog License. I would contact Graylog support here about this. It may have something to do with the license.
Thanks, we have Graylog Enterprise license with the portal saying no license issues. There’s some license check failures, but have verified that the Graylog box can reach the API
Understood, I would reach out to Graylog Support about this since you have a license.
Thanks, have now done so
Support has stated that the license doesn’t qualify for support, so I’m reaching out to the community. Does anyone have any suggestions as to how to resolve this, or where to start looking?
The license we have (open source) does qualify for the Office 365 plugin, and we have many tenants already connected… It’s just when adding new ones it fails. Thanks in advance
This reads to me as something is wrong in the settings on the Azure configuration side - perhaps with permissions - you have gone over your process with the docs? with client applications permissions specifically and enabling unified Audit Logging?
Thanks. I’ve tried again with the tenant and it looks like it’s working now… Perhaps it just needed more time? Unified logging was enabled just prior to adding the input, so perhaps it takes more than an hour. Anyway, it’s working and looks like it was just about waiting for time.
Thanks everyone
Great!! Maybe just jostling it a bit loosened up a couple of fouled bits… :stuck_out_tongue:
