Grok Parse in Pipeline (bug or invalid escapes?)
Hey all,
Just found this. Trying to parse a few URIPATHs (field is URI_path) that look like this:
section=bottom&templateUrl=https://www.domain1.ca/parser.asp?app=tickets
section=doctype&templateUrl=https://www.domain1.ca/parser.asp?app=tickets
section=doctype&templateUrl=https://www.domain2.ca/en/Parser.asp
section=bottom&templateUrl=https://www.domain2.ca/en/Parser.asp
All I care about is domain1/domain2 and the app being used:
section=%{WORD:parse_section}&templateUrl=https://www.%{WORD:parse_organization}.ca/(en/)?(p|P)arser.asp(\?app=%{WORD:parse_application})?
works in the grok debugger… but fails in the pipeline rule. I’m sure there is a character throwing it off - but I seem to keep finding new and creative ways to break out of my grok/regex strings. Can anyone spot where I’m messing it up?
Full rule
rule "Simplify IIS Parse URI"
when (
    has_field("log_type") AND
    contains(to_string($message.log_type),"IIS",true)
    ) AND (
    has_field("URI_path") AND
    contains(to_string($message.URI_path),"/parser/parser.ashx",true)
let unparsed = to_string($message.URI_path);
let parsed = grok(pattern:"section=%{WORD:parse_section}&templateUrl=https://www.%{WORD:parse_organization}.ca/(en/)?(p|P)arser.asp(\?app=%{WORD:parse_application})?",value: unparsed,only_named_captures: true);
set_fields(parsed);
UPDATE: This exact pattern works in the GROK extractor for any test message - but still won’t save in a Pipeline.
UPDATE 2: The escaped ? at the end of the the URI_path was the culprit. I had to double-escape it in the pipeline rule - lets see if it still processes. I’ll post back.
UPDATE 3: Editor allows me to save the rule, but it won’t extract.
UPDATE 4: This is the GL processing error:
For rule 'Simplify IIS Parse URI': In call to function 'grok' at 13:13 an exception was thrown: Unknown inline modifier near index 77 section=(\b\w+\b)&templateUrl=https://www.(\b\w+\b).ca/(en/)?(p|P)arser.asp(?app=(\b\w+\b))?
My regex sucks, so I can’t figure out where its wrong.
I personal would place the working GROK Pattern into a new GROK pattern in your System (System > GROK-Patterns) and use that single word in the processing pipeline. That prevents you from the double escape you need in the editor.
That’s a common occurence. You have to use double escapes on all special characters, so instead of
\(en\)
You’ll have to put
\\(en\\)
in the graylog grok-Filter.
