Graylog woes: journal utilization, process buffer and other issues
This is frustrating!
A new cluster (2x GL + 3x OpenSearch) deployed on Azure cannot cope with the load that a single GL instance, also on Azure, handles.
  • OS Information: Ubuntu 20.04 LTS
  • Package Version:
    GL 4.3.5
    OS: 1.3.3
    Each GL node (x2) has 16 GB RAM, 8 vCPUs
    Each OS node (x3) has 16 GB RAM, 8 vCPUs
/etc/graylog/server/server.conf
$ grep -v \# /etc/graylog/server/server.conf | uniq
is_master = true
password_secret = XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
root_password_sha2 = XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
root_email = "email@domain.tld"
elasticsearch_version = 7
trusted_proxies = 127.0.0.1/32, 1.2.3.4/32
elasticsearch_hosts = http://admin:admin@node-1:9200,http://admin:admin@node-2:9200,http://admin:admin@node-3:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
elasticsearch_index_optimization_jobs = 30
output_batch_size = 5000
output_flush_interval = 1
processbuffer_processors = 2
outputbuffer_processors = 2
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_age = 12h
message_journal_max_size = 10gb
mongodb_uri = mongodb://mongodb-node:27017/graylog
prometheus_exporter_enabled = true
prometheus_exporter_bind_address = 127.0.0.1:9090
/etc/default/graylog-server
$ cat /etc/default/graylog-server
# Path to the java executable.
JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms4096m -Xms4096m -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow"
# Avoid endless loop with some TLSv1.3 implementations.
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true"
# Fix for log4j CVE-2021-44228
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true"
# Pass some extra args to graylog-server. (i.e. "-d" to enable debug mode)
GRAYLOG_SERVER_ARGS=""
# Program that will be used to wrap the graylog-server command. Useful to
# support programs like authbind.
GRAYLOG_COMMAND_WRAPPER=""
/etc/opensearch/opensearch.yml
$ grep -v \# /etc/opensearch/opensearch.yml
path.data: /data/opensearch
plugins.security.ssl.transport.pemcert_filepath: cert.pem
plugins.security.ssl.transport.pemkey_filepath: cert.key
plugins.security.ssl.transport.pemtrustedcas_filepath: root-ca.pem
plugins.security.ssl.transport.enforce_hostname_verification: false
plugins.security.ssl.http.enabled: false
plugins.security.ssl.http.pemcert_filepath: cert.pem
plugins.security.ssl.http.pemkey_filepath: cert.key
plugins.security.ssl.http.pemtrustedcas_filepath: root-ca.pem
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
[ LDAP stuff removed ]
plugins.security.audit.type: internal_opensearch
plugins.security.enable_snapshot_restore_privilege: true
plugins.security.check_snapshot_restore_write_privileges: true
plugins.security.restapi.roles_enabled: ["all_access", "security_rest_api_access"]
plugins.security.system_indices.enabled: true
plugins.security.system_indices.indices: [".plugins-ml-model", ".plugins-ml-task", ".opendistro-alerting-config", ".opendistro-alerting-alert*", ".opendistro-anomaly-results*", ".opendistro-anomaly-detector*", ".opendistro-anomaly-checkpoints", ".opendistro-anomaly-detection-state", ".opendistro-reports-*", ".opensearch-notifications-*", ".opensearch-notebooks", ".opensearch-observability", ".opendistro-asynchronous-search-response*", ".replication-metadata-store"]
node.max_local_storage_nodes: 3
cluster.name: "opensearch-cluster"
node.name: "node1"
network.host: "1.2.3.4"
http.port: 9200
bootstrap.memory_lock: true
discovery.seed_hosts: ["node-1","node-2","node-3"]
cluster.initial_master_nodes: ["node-1"]
node.roles: ['data', 'master']
The main issue:
The funny part:
which seems to match with:
$ curl http://$(hostname):9200/_cluster/health?pretty=true
  "cluster_name" : "opensearch-cluster",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 3,
  "number_of_data_nodes" : 3,
  "discovered_master" : true,
  "active_primary_shards" : 733,
  "active_shards" : 755,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
I installed ElasticHQ and, overall, things look good:
I read almost every entry about this topic I found on the forum and applied the proposed solutions but no luck…
This is the current situation:
This is similar on both GL nodes:
where millions of mesages are unprocessed and the main “Search” page or the “Sources” dashboard are not showing anything either…
The most worrying parts are:
  1. not all applications are sending their logs to the new cluster, so there’s more load to come…
  2. the old Graylog 3.2.6 VM (32 GB RAM, 16 vCPUs) could, single-handed, deal with more load than the current clustered version
Read the docs, read the forum, applied solutions proposed.
First of all, I would like to reach a battle-proof state with this cluster based on GL+OS. Nowadays it is not, despite all the resources…
Does the fact that 2x GL nodes and 3x OS nodes are deployed could be a bottleneck by having 1 GL node less? In other words: would a 3x GL + 3x OS cluster solve the issue?
Are there any settings I should fine-tune?
Does the cluster need to be beefed up with more resources? if so, RAM? CPU?
Thanks a lot in advance for your assistance!
Best regards
Hello @m_mlk
After looking over your configurations, I really don’t see an issue. 90 % of the time when the Journal fills up is a connection/resource issue.
Elasticsearch/OpenSearch needs access to the journal to index those messages. It also needs the resource to index those logs.
BUT depending on the circumstance, I would make sure ES/OS is NOT is a readable state, this will prevent ES/OS for indexing /write those logs.
Maybe I’m blind but I don’t see OpenSearch version your using? So I assume your have the correct version of OpenSearch?
As for any settings that could be a issue is this one, that is your heavy hitter buffer_processor
If you have the resources I would set it to something like this on all your GL nodes.
processbuffer_processors = 5
Check list:
  • Make sure Opensearch is not a readable state. Something like this…
GET  your_index/_settings
  "index": {
    "blocks.read_only": true
  • Check Graylog/OpenSearch Log files, This may narrow down what the issue is.
EDIT: I am blind, just seen you OS version :laughing:
