Graylog with opensearch compression codecs
Its a bit unclear if graylog 6.x created indices use compression of some sort or not (see: Index codecs - OpenSearch Documentation). I suspect not.
How would one go about managing the codec options in the community version? I do not find any references/mentions of compression options in the graylog documentation or in the various “indices” menu of graylog itself.
Thanks for any pointers.
Hello @rodney_vdw,
Options regarding compression can not be influenced from Graylog, regardless of which version you are running.
