I’ve been looking for a way to make gl/es consume less disk space. I’ve found this post with the suggestion to set index.codec to best_compression. But how do you do that? The doc mentioned in the article says to create a template for graylog to write to elasticsearch. Is there another way? I just want to increase the compression ratio and leave everything dynamic.
Cheers
