Graylog Storage related
I have installed graylog 5.0 and opensearch 2.9. Currently we have 5k eps and index size for daily 180 GB. currently we have out off storage. I have done lot of research related to store the data and found that opensearch has storage compression feature with zstd with dictionary. i am looking for plugin but no luck. please help me for the same.
  • OS Information: CentOS 7.7
  • Package Version: 5.0
As far as I know this would need to be set via the index template in OpenSearch which isn’t supported with graylog.
Thanks for your reply.
What is the best option available to store 1 year data with compression?
Also I have observed ArcSight or Other paid solution provide the 10:1 compression level so how to achieve similar compression in Graylog.
Thanks.
The archive feature supports compression, but it is a paid/licensed feature only.
