I installed the graylog3 in a kubernetes EKS cluster. I am using nginx-ingress-controller.
However, the WEB interface does not work with HTTPS.
What settings on nginx-ingress do I have to enable?
Installing nginx-ingress
helm install nginx-ingress --namespace nginx-ingress \
--set rbac.create = true \
--set controller.kind = DaemonSet \
--set controller.service.enableHttps = false \
--set controller.service.type = NodePort \
--set controller.service.nodePorts.http = 30000 \
--set controller.metrics.enabled = true \
--set controller.service.annotations. "kubernetes \ .io / ingress.class" = alb stable / nginx-ingress --version 1.36.0
Graylog installation
helm install graylog -n graylog \
--set graylog.rootPassword = xxxxxxxxx \
--set graylog.rootEmail=it@company.org \
--set graylog.metrics.enabled = true \
--set graylog.ingress.enabled = true \
--set graylog.ingress.port = 30000 \
--set graylog.ingress.hosts.0 = graylog.dev.company.org \
--set graylog.externalUri = graylog.dev.company.org stable / graylog --version 1.6.2
I didn’t find anything in the helm graylog documentation about configuring nginx-ingress.
I’ve been trying to make graylog work in the kubernetes cluster for days with nginx-ingress.
Could you please help me?
