Hi all,
Graylog version 2.4 sometimes showing blank screen while loading the web interface. Can you please answer me why this is happening. Also, there is no backlog on any data nodes.
Elasticsearch version that I am using is 5.6.4
Thanks in advance
Hi all,
Thanks in advance
Sorry your question is not clear.
Graylog is a single page application that, it might happen when your browser is not able to get the backend information in time that you end with a with page - e.g. that the request run into a timeout. The load on your nodes might be to high.
But without more details this is just guessing.
Thanks @jan
The problem is solved now …
sharing the solution might help others!
I added the dedicate node for web-Interface and it solved the problem.
