Graylog Web Interface only showing behind LB
I have Dockerized Graylog Deployed successfully with the following docker-compose config:
version: "3"
services:
    mongodb:
        image: mongo:latest
        container_name: mongo
    elasticsearch:
        image: elasticsearch:latest
        container_name: elasticsearch
    graylog:
        image: graylog:latest
        container_name: graylog
        environment:
            #Using server IP
            - GRAYLOG_WEB_ENDPOINT_URI=http://10.179.84.64:9000
        links:
            - mongodb:mongo
            - elasticsearch
        depends_on:
            - mongodb
            - elasticsearch
        ports:
            - 9000:9000
            - 514:514
            - 514:514/udp
            - 12201:12201
            - 12201:12201/udp
The issue is, I can only view the Web Interface behind the LB/firewall on port 9000, however the UI doesn’t show outside of LB: http://<website>.com:9000
I have launched Grafana on the same exact port and server and its was successfully viewable on : http://<website>.com:9000
Is there some sort of specific settings I need to configure for Graylog?
I even following these instructions but didn’t have any luck:
http://docs.graylog.org/en/2.3/pages/configuration/web_interface.html
Using a Layer 3 load balancer (forwarding TCP Ports)
  • Configure your load balancer to forward connections going to 192.168.0.10:80 to 127.0.0.1:9000 (web_listen_uri) and 192.168.0.10:9000/api/ to 127.0.0.1:9000/api/ (rest_listen_uri).
    — In my case its VIP to Server IP:Port
  • Set web_endpoint_uri in your Graylog server config to http://graylog.example.org:9000/api/.
  • Start the Graylog server as usual.
  • Access the web interface on http://graylog.example.org.
What does that mean exactly?
So the way our network is setup is, if a client hits http://<website>.com:9000, it first goes to the Load Balancer/firewall, then comes to our server
Now if I view Graylog behind Load Balancer/Firewall, I am able to view the Web UI http://<HOST-IP>:9000. Issue is if I try to access it out side Load Balancer/Firewall, Web UI doesn’t show.
I make sure Load Balancer/Firewall are correctly setup by launching another app on port 9000 like Grafana, which showed up without any issues.That made me think that maybe Graylog config needs to be setup in a certain way.
You have to set web_endpoint_uri to the URI of the Graylog REST API which is accessible for your web browser.
Thanks,
I have set the web endpoint to following, which is the server ip. With this I am able to access it behind the LB/firewall, but not outside still. Not sure why Graylog doesn’t show up outside while other apps do without any issues.
Is http://10.179.84.64:9000 really the correct URI for the Graylog REST API?
Are you sure about that?
Just asking because 10.179.84.64 looks a lot like an IP address from the 10.0.0.0/8 IP range defined in RFC 1918. In other words, it’s a private IP which can only be accessed within your network.
I have tried our external IP too which I get when I ping our site URL to test that out. That didn’t work either unfortunately.
Using the external IP, I get “Server currently unavailable” when view Graylog BEHIND the LoadBalancer/firewall
When use server IP, I am able to view and login Graylog
I think you need to set all servers to use the address of the server. You should not use the VIP address in graylog config at all. I.e. if your servers are 10.0.0.1 and 10.0.0.2, you use these IP addresses in the server configs. The VIP address is used only in the load balancer config.
Then, setting up https, depending on how you set it up (whether the load balancer is passing through TLS or not), you might need to set both vip and the server ip addresses and names in the certificate.
After a quick rethinking. If the server works fine, it must be your load balancer config anyway. If you load balancer does not report any error, you could also try using tcpdump on the graylog server to see whether any traffic comes to the graylog port.
And this is the documentation on how to configure load balancer info: http://docs.graylog.org/en/2.3/pages/configuration/load_balancers.html
There is not much special, but the cluster status url to the master node.
Thanks,
I have been messing around a little more, but still didn’t have much luck. @jtkarvo, so my thinking was the same, that the issue is on Load Balancer side. However I deployment Grafana using the same port, and it came up fine, which makes me think that its the way Graylog is showing its UI that needs to be configured. I even have Jenkins running in the same setup.
another update:
We actually have two Load Balancer in our network, what I did was, I launched GRAFANA with port 9000 and I was able to reach it following URLS:
Load Balancer VIP 1: IP:9000
Load Balancer VIP 2: IP:9000
HOST: NAME/IP:9000
Then I launched again GRAYLOG on port 9000 and I was ONLY able to reach it on:
HOST: NAME/IP:9000
I tried setting WEB_ENDPOINT_URI to URL, VIP 1 IP and VIP 2 IP, but unfortunately none of those worked.
Another thing I guess Ill try is to get older version of Graylog to see if that works.
Not sure if anyone else needed to do this,
Right now only port 9000 is setup to go externally outside firewall/load balancer. Would I need to do setup anything else ?
