I have downloaded GrayLog OVA disk and run VMWare machine.
Then did as described:
$echo -n | shasum -a 256
The result copy and paste to /etc/graylog/server/server.conf
root_password_sha2=xxxxx
Then I have decided to upgrade the GL 3.3.8 to the latest one.
I have updated it using recommendations on GL site, server.conf was replaced with new one. I have generated hash again and added to the config
After restart VM this request http://10.0.0.72:9000/dashboards
returns 404
Considering the time it would take to troubleshoot this problem, my recommendation would be to ditch the OVA and built a fresh all in one node on your preferred linux distro. That way there is no upgrade path to have to worry about.
I have installed VMWare Ubuntu 22.04 Desktop, inside Ubuntu in Software installed Graylog, modified server.config (added secret_pasword and hash for the new admin password). After Ubuntu VM reboot tried in host machine browser http://10.x.x.x:9000
404
Even on local VM 127.0.0.1:9000
Firefox can’t establish a connection to the server at 127.0.0.1:9000.
What are your http_bind_address , http_external_uri and http_publish_uri settings within your /etc/graylog/server/server.conf file?
Also, what is your route from browser to graylog server? I.e. are you on the same subnet? Are you traversing the WAN? Do you have a firewall enabled on your Graylog Server hypervisor and/or guest?
EDIT: Final question:
what does /var/log/graylog-server/server.log say? The web interface will fail to come up if it is failing to connect to opensearch/elasticsearch and/or mongodb.
I have run web interface after read server log file to the end and found the password there.
Ok, I have logged id with the temp pwd and then in the browser appeared initial page; ca, policy and requirement to add node.
I have installed the node in terminal, return back to browser and web page disappeared.
I read GL-server log:
INFO [cluster] Exception in monitor thread while connecting to server localhost:27017
com.mongodb.MongoSocketOpenException: Exception opening socket
