Graylog VM running on AWS
I really would like to use graylog but having difficulty.
I have launched a the version 2.2.3 or 2.2.1 on AWS and follow the instructions to set the external ip address, and reconfigure the server but no matter what when I try to connect to the server using a web browser the server says that the server is unavailable and it shows the internal IP address of the server.
What can I do to get past this very introductory issue that is blocking me from using Graylog.?
What exactly did you do and what was the output of the commands you’ve executed?
