Fresh Amazon AMI instance is not reachable
I just created a new Graylog AMI to test. Following the instructions, I attempt to connect to the instance’s public IP, I receive an error " Graylog is currently not reachable…".
Checking the AWS side, I’ve ensured that port 80 is open, there should be no firewall issues to the instance.
I’ve also tried <public ip>:9000, but that times out. To make sure it wasn’t an instance performance issue, I switched to a large instance and get the same result.
I’ve also tried changing the config file to add my public IP as the external address, but again, no effect.
How can I get connected?
I spent more time on this, I terminated and recreated the an instance with the AMI image. It now works if I go to the ip address directly.
Now my issue is that I would like to run it behind an Amazon ELB, which behaves like a reverse proxy. How do I get the AMI install to work with an address such as http://mydomain.com/graylog?
@mullenba
the documentation covers that: http://docs.graylog.org/en/3.0/pages/configuration/web_interface.html#making-the-web-interface-work-with-load-balancers-proxies
It is not a step-by-step guide but the pieces are given.
How about more details on how to set up the server.conf file for situations like www.example.com/graylog?
