Graylog stops processing messages seemingly at random times
My instance of Graylog sometimes (about twice a day) stops processing messages. The messages are getting written to the message journal and a restart of Graylog (using systemctl restart graylog-server) fixes the issue temporarily. The logs in the journal get processed and then written to Elasticsearch.
I can see no errors at all in either the Graylog or Elasticsearch log files.
I am a bit stuck on what to do here. Any pointers would be appreciated
I am running Graylog 3.1.4 on 1 server
then on another server I am running elasticsearch 6.8.9
I have some thread dumps from the time that the issue happens. If they would be useful let me know and I shall post them.
Thanks!
he @oidz1234
you should investigate what is happening during this time? Does your Elasticsearch is having problem? Check what does happen in the system and you will get a trace.
My elasticsearch seems to be perfectly fine.
I have gotten a trace from graylog, I am not sure how to read it or what to look for as it’s very long. Would you like me to post this trace?
from such a time you want to create a processor buffer dump on the System > Nodes page. This allows you to see what the processing processors do.
I do not seem to have that option? I am on graylog 3.1.4
2020-06-03-100728_524x339_scrot
ok - that is added in 3.2 AFAIK … sorry. Without that it is nearly impossible to find what the reason for this is.
Ok, I will try and get Graylog upgraded to 3.2 next week.
